Pod Filter In Airbox
BAILED
 Share
You would be better off putting an aftermarket panel filter in your airbox rather than think about putting a pod in one. The main problem being is that the air still has to flow down a restrictive passage (opening to airbox ) before it even makes it to the pod filter.
The reason pod filters are more effective than airbox's is that they have more surface area to allow more air to be pulled through and into the motor with less restriction.
As for legalities, pod filter's are legal modifications in all states (I believe so) and if you have any troubles just get a permit when (and you will due to it being a GTR) you get a defection sticker.
Edited by Baz
The panel filter on the VT V8 Commode fits the GT-R. Autobarn should be able to sell you one.
It is not too complicated a job to plumb in the stock airbox to larger cold air feeds. You can take the resonator off the bottom of it for starters.
Baz - before i can make it legal in any way i would have to drive 600km to a EPA test station so they can run a 15 minute test. i have to do that before i can get it engineered. yes thats what the cops want me to do so im trying to make it stock.
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
