Hi,
was just wondering how the dampening system works on Tein HA's. Whilst on the car, do you turn the pin at the top clockwise or anticlockwise for a "softer" ride?? Is it supposed to click or just turn like a normal screw thread??
Need help urgently as my shocks are so bloody stiff atm.
https://www.sau.com.au/forums/topic/88646-tein-coilovers/
Hi,
Anticlockwise for softer, clockwise for harder. Adjusting the rebound damping may not help, Teins usually come with rediculously high spring rates.
:rolleyes: cheers :rolleyes:
https://www.sau.com.au/forums/topic/88646-tein-coilovers/#findComment-1600886
Mmmm they do seem to be rediculessly hard....is there any specific tool which should be used to adjust these pins at the top?
Mine do not click it just rotates like a screw thread.... What could this mean?
How can you tell whether ur coil overs are in need of reconditioning??
Cheers for the help so far...
https://www.sau.com.au/forums/topic/88646-tein-coilovers/#findComment-1602799
well wat happens...say this arvo...i wound it anti clockwise a turn and a half.....it doesnt click but turns easily... (bit too tight for fingers.... used vice grips)....then hopped in went for a drive and it is a bit softer....but still yet no click.....
what do you think?
https://www.sau.com.au/forums/topic/88646-tein-coilovers/#findComment-1602913
I seriously doubt that 1 click if noticeable to the human bum... but then my ass is not sensitive :P
Umm, maybe the spring that makes it "click" has gone... could be that you're just screwing it instead of clicking? Try wind it all the down and see if it makes a difference?
https://www.sau.com.au/forums/topic/88646-tein-coilovers/#findComment-1602947
mate I had this issue with the HA adjustment nut turning under its own steam....
fix:-
tighten the lower part that is the nut to the shaft....
once that is tight, hold the seperated part at the top and turn it.... it should now click as long as the lower part does not free up :O
simple...
https://www.sau.com.au/forums/topic/88646-tein-coilovers/#findComment-1612902
thanks satanic...will adjust mine this weekend.They are super hard so im hoping they have some adjustment left in them for a softer ride.
I never got mine with upper pillow ball joints-is anyone else using them?
what does the adjustment do for handling?
https://www.sau.com.au/forums/topic/88646-tein-coilovers/#findComment-1613549
those ones in the pic above don't look like HA to me. HA usually have a little nurled adjusting 'knob' on the top with a little rubber cap that goes over it. yours look like the non-adjustable type. do you have a more close up pic of the strut top?
https://www.sau.com.au/forums/topic/88646-tein-coilovers/#findComment-1613564
yeah he could have lost the caps (i lost two on my old car) but usualy under the caps is a round, nurled knob (with a hex type fitting on top). his one has the flat sided tops. they don't look damper adjustable to me.
https://www.sau.com.au/forums/topic/88646-tein-coilovers/#findComment-1613733
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
