Hi,
was just wondering how the dampening system works on Tein HA's. Whilst on the car, do you turn the pin at the top clockwise or anticlockwise for a "softer" ride?? Is it supposed to click or just turn like a normal screw thread??
Need help urgently as my shocks are so bloody stiff atm.
https://www.sau.com.au/forums/topic/88646-tein-coilovers/
Hi,
Anticlockwise for softer, clockwise for harder. Adjusting the rebound damping may not help, Teins usually come with rediculously high spring rates.
:rolleyes: cheers :rolleyes:
https://www.sau.com.au/forums/topic/88646-tein-coilovers/#findComment-1600886
Mmmm they do seem to be rediculessly hard....is there any specific tool which should be used to adjust these pins at the top?
Mine do not click it just rotates like a screw thread.... What could this mean?
How can you tell whether ur coil overs are in need of reconditioning??
Cheers for the help so far...
https://www.sau.com.au/forums/topic/88646-tein-coilovers/#findComment-1602799
well wat happens...say this arvo...i wound it anti clockwise a turn and a half.....it doesnt click but turns easily... (bit too tight for fingers.... used vice grips)....then hopped in went for a drive and it is a bit softer....but still yet no click.....
what do you think?
https://www.sau.com.au/forums/topic/88646-tein-coilovers/#findComment-1602913
I seriously doubt that 1 click if noticeable to the human bum... but then my ass is not sensitive :P
Umm, maybe the spring that makes it "click" has gone... could be that you're just screwing it instead of clicking? Try wind it all the down and see if it makes a difference?
https://www.sau.com.au/forums/topic/88646-tein-coilovers/#findComment-1602947
mate I had this issue with the HA adjustment nut turning under its own steam....
fix:-
tighten the lower part that is the nut to the shaft....
once that is tight, hold the seperated part at the top and turn it.... it should now click as long as the lower part does not free up :O
simple...
https://www.sau.com.au/forums/topic/88646-tein-coilovers/#findComment-1612902
thanks satanic...will adjust mine this weekend.They are super hard so im hoping they have some adjustment left in them for a softer ride.
I never got mine with upper pillow ball joints-is anyone else using them?
what does the adjustment do for handling?
https://www.sau.com.au/forums/topic/88646-tein-coilovers/#findComment-1613549
those ones in the pic above don't look like HA to me. HA usually have a little nurled adjusting 'knob' on the top with a little rubber cap that goes over it. yours look like the non-adjustable type. do you have a more close up pic of the strut top?
https://www.sau.com.au/forums/topic/88646-tein-coilovers/#findComment-1613564
yeah he could have lost the caps (i lost two on my old car) but usualy under the caps is a round, nurled knob (with a hex type fitting on top). his one has the flat sided tops. they don't look damper adjustable to me.
https://www.sau.com.au/forums/topic/88646-tein-coilovers/#findComment-1613733
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
