I'm looking at buying an R32 GTR but since looking at few i notice that all the ones i have seen have a bubble in the dash and around the rear windows the vinyl has gone sticky and peeled away from the windows itself. Are they all like this? What causes this, age, heat, what? Can this be fixed easily?
https://www.sau.com.au/forums/topic/88656-r32-interiors/
In short yes. These are two of the most common signs of ageing on this model. But you can also add:
Wear to the velour trim on the seats.
Wear to the steering wheel/leather handbrake & gear covers.
Stuffed window seals front & rear.
https://www.sau.com.au/forums/topic/88656-r32-interiors/#findComment-1601508
Ah yes, the plastic shrinkage issue. Make that 'farking plastic shrinkage issue'.
I have not been able to find a trimmer that can either repair the dash/window surround or recover them in a similar grain.
New window surrounds are only about $300 new from Nissan, a new dash is about $1200. Recovering the dash is about $500 but then you have to redo the rest of the interior.
It's a shite sandwich either way but as femno said you can get them with good dashes.
https://www.sau.com.au/forums/topic/88656-r32-interiors/#findComment-1601518
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
