Hi Ppl's
Sorry for asking, but:
What is the standrad flow rate of both a series 1 and series 2 Stagea RB25DET Wagon?
ie, Litres per Hour.
Looking at upgrading my standard fuel pump, want 180-200kw at the 4wheels (after my turbo upgrade), is 130L/h enough? Looking at a Power Enterprises fuel pump to suit the Stagea from www.nengun.com
Have a Nismo adjustable fuel pressure regulator, and am going to upgrade the fuel lines to high pressure items as well.
And yes, done a bit of a search, but not going to trawel through 6000 pages to find the correct info - anyone? Im sure someone knows....
Brendan
Edited by bwilkeson
https://www.sau.com.au/forums/topic/88670-fuel-pump/
Hi Ppl's
Brendan
The Standard Stagea fuel pump supplies 135 litres per hour at 12 volts. If you run a relay and a separate power supply back to the battery they will flow 160 litres per hour at 13.8 volts. That's enough to supply 6 X 444 cc injectors which = 444 bhp or 250 4wkw.
Regardless of what fuel pump you use, you should always run a relay and a separate power supply back to the battery, the standard wiring harness doesn't handle the extra current. Just use the standard wiring to switch the relay and upgrade the earth wiring and run a 30 amp fuse and wiring to the battery positive.
:P cheers :)
https://www.sau.com.au/forums/topic/88670-fuel-pump/#findComment-1603024
;) cheers :(
Mate, thats awesome information!! :)
Thanks so much for the advice, I hope that helps others out as well. I reckon that sounds like it could be a good path to follow in lieu of upgrading the pump.
Cheers again, Brendan :P
https://www.sau.com.au/forums/topic/88670-fuel-pump/#findComment-1604875
Hi all,
Did a search last week in regards to the fuel pump, and in the DIY section there is a good tutorial in how to install a tomei direct replacement fuel pump.
After further searching, Im sure I found some info that suggested that the Stagea fuel tank had the same part number of the R32GTR and that the R32GTR fuel pump should fit.
For the life of me I cant seem to find that info again....(at work, need more time!)
Can anyone here with Stagea's confirm this information?
Cheers - Brendan
https://www.sau.com.au/forums/topic/88670-fuel-pump/#findComment-1608375
Hi all,
Cheers - Brendan
Skyline pupms are pretty much interchangeable, I have an Z32 pump in the R32GTST, it is bascially the same as the R32GTR pump. I don't see any reason why the Stagea would accept (wiht a few little mods) any R32/33/34 Skyline pump.
:P Cheers :O
https://www.sau.com.au/forums/topic/88670-fuel-pump/#findComment-1608993
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
