Rb20 Misfire
browndog
 Share
ok well i have a cerfiro with an rb20det which has developed a intermittent misfire. It has had a miss for about 4 months but only at idle it would just miss a bit at the lights didnt really bother me, but now it misses while driving down the highway at 100k's, as if it is constantly missing on 1 cylinder, it makes the front of the car shake, it does it for a bit then goes away, then comes back. i changed the plugs and looking at the coil packs only 2 of them seem to have good electrode things coming out of the pack, the rest are burnt and worn away and number 6 plug had a bit of soot on it. so i figured it was that however i took the plug off each coil pack while it was running at idle and i can still hear a miss for every cylinder. I even took two lead off too see if 2 coil packs were missing but no it still misses. I changed the air flow sensor and it still does it. I pulled the codes out of the computer and came up with knock sensor and maf sensor error then i reset them and ran it and it wont register any codes now though sometimes when i rev the engine the check engine light comes on, but when i go to check the codes 55!?! cant figure it out, if it was the ignitor surely it would only miss on one cylinder unless it was the earth curcuit of the ignitor which i will check. Other wise i am thinking computer?? Tps wouldnt do it would it??
any help would be appreciated thanx. Dog
 Share
    • Thanks for the reply, So i've continued playing around, and fitted the injector adaptors onto the injector, the fuel rail is not able to be mounted now as the injectors sit a bit further out. I suppose the point of the adaptors is so that the injector nozzle isn't so deep into the intake? I suppose 1mm extra on the o-ring would do it but still can't mount the rail onto the intake haha. Waiting on a reply from Aeroflow I'm sure there's something stupid that I'm missing...
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
