Hi guys, just made 340AWKW at CRD today with our street exhaust.
I have yet to see the Dyno graph but jim said the car made more low end about the same mid range and more top end with the JUN plenum and QF45 throttle body.
tomorrow i'm going over to but the 4"exhaust on and then we will do another power run and just check it over to make sure everything is ok!
Last time the race exhaust made another 30AWKW on top, with out any tuning.
I'll post up again later to tell you how it all goes.
Cheers
https://www.sau.com.au/forums/topic/88735-340kw-at-the-wheels-on-gt-ss-turbos/
Hi,
we ran the car up again with the 4" exhaust today.
we made another 20AWKW =360AWKW
I beleive the problem is now that the airbox we had made(which is designed for max power with the headlight out).Could now be starving the car of air with the head light in.
The car is pretty mad to drive!
The next mods to the car with be a new intercooler and a fibreglass funnel to the airbox from where the head light is.
A BIG thanks goes out to Jim and the gang at Croydon Racing Developments for the great job tuning the car .
Another reason for not making more power with the big exhaust is that the turbo's can't keep the pressure up with the new plenum.
I would like to try a set of GT-RS turbo's on the car.
I think that the good old GT-SS turbo's are pretty much out of puff!!
we'll see what has to be done to make some more power down low.
Cheers
Sorry i forgot to add that was on 22psi down to 21psi andf running BP 98.
shit so thats 612hp at all fours or am i mis-calculating :)
i dont doubt the figure i just wondered if i worked it out right and damn thats impressive numbers for little low mounts :D
good luck
Brad
Sorry that's not right.
22>21 made 340AWKWs quite exhaust
22>21 made 355awkws big exhaust.
27 psi made 360big exhaust
as you can see the turbos are out of puff by then anyway.
I'm not sure how much that is at the wheels in HP.
Again thanks to the Guys at CRD!
Congratulations :D
Looks like Jim is definitely on top of these GT-SS turbos :O
What are you plans for the car? I wouldn't put a pair of GT-RS on a stock capacity RB26 if I were you. The car won't be anywhere NEAR as fun to drive.
Full mod list?
i belive this car runs a JUN 2.7lt strocker and JUN plenum i would like to see what GTRS can do
I'm not quite sure what an extra 100cc would do in spooling up the GT-RS, but I'm interested to see if 600hp is willing to take the chance and show us :D
All the UK tuners (who have been testing with the GT-RS's for the last 3 years) readily agree that you need at LEAST a 2.8 stroker or preferably a 3.0 OS Giken kit to get the GT-RS's to spool early enough for a road car.
From what I've noticed building a 3ltr then comparing it to the 2.5 and 2ltr, it appears for every 500cc increase you improve spool by ~600rpm.
Its the torque that makes the biggest difference.
Edited by Cubes
I don't really understand the following that these GTRS's have on an RB26 , I cant see the point of extra capacity to excite turbo's that are so so to start with . 2530's would have far better response than GT-RS's (GT2871 52 trim's) so what gives ? If someone went to the same lengths with these turbo's (2530) as WilliamsF1 did with GT-SS's surely the torque at the wheels would be adequate and very progressive . I think Gary mentioned some good times with them but cant I remember the numbers .
Cheers A .
Hows it going 600hp
Do you think you have found the limit of the GT-SS
at the 360awkw? (great effort by the way)
I hate it when people talk what boost by when (cos it really has no relationship to power and torque) But i would be interested to see the torque curve you achieved as to me it's the most important thing as it's what drop you back in the seat and keeps you there lol.
pete
ps great to see you posting results again cheers
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
