Hey all,
Looking to upgrade my battery, preferably with an Optima Yellow Top (stock battery doesn't really like the new stereo, plus it's a bit old anyway).
At the moment looking at getting the D51R Yellow Top - it's one of the smaller ones, but I think it should have enough power for me. Anyway, I've heard that you might need to make minor modifications to make the battery fit - new terminals, battery clamp, etc.
So if anyone has an Optima in their car, can you post up:
a) which model
B) what modifications were required to fit it?
Thanks!
Vijay
https://www.sau.com.au/forums/topic/88737-skylines-and-optima-batteries/
yes, you will have to get one of the smaller ones....
I have a tall yellow top optima and it doesnt fit in the standard spot under the bonnet..
and yes new battery clamps are needed as the standard ones are too small to fit onto the Optima
you can have the battery's posts changed if you want to stick with your original clamps.
and yes, chances are slim putting a d34 under a bonnet normally, but keep in mind, the optimas are happy on any angle at all, so you can mount them on their side no problems at all!
otherwise, throw it in the boot!
d
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
