The RED one is a NICS engine. It is the earlier of the 2. And has less power.
The NICS has 2 inlet runners per cylinder, 1 of which has a butterfly that opens and closes depending on the requirements. These tend to jam, so that the engine is either terrific down low and crap up high, or crap down low and terrific up high.
The heads are different, but interchangeable (I know the inlet manifolds are not interchangeable).
That's my limit. Anyone else add or correct.
Greg you are correct in your description of the early NICS engines, but there was also a red-top ECCS version of the RB20DET which was used in HR31's from about mid 1987. The red ECCS uses a very similar manifold setup to the R32 silver type - in fact it looks largely identical, but there might be detail differences. The (rough) power output of the three types is:
NICS - 140kW
red ECCS - 150kW
silver ECCS - 160kW
Probably the main differences between the R32 ECCS and the R31 ECCS is that the R32 used a ball-bearing turbo (R31 used plain bearing) plus the R32 had a more refined engine management system. That said there are probably internal detail differences, but I haven't compared them.
To complicate matters somewhat, the silver ECCS engine was also used in some late model Cefiro's, but for some reason the Cefiro version used a plain bearing turbo (like R31's) - well that's what I'm lead to believe, anyway.
Nics and red eccs are both 12 port heads and silver is 6. The red eccs actually also has the same inlet butterflies as the nics but has a 6 runner manifold like the silver.
There are many minor differences between the silver and red eccs like injector sizing, impedance, fuel rails, throttle body sizing, sensors, ecu etc. Do a search as it was covered very recently.
In what way? I have a red eccs in the GTS-R and its 100% a 12 porter and it 100% had the butterflies as I removed them.
Its not uncommon for people with red top eccs engines to ditch the butterflies and manifold and use the silver top gear instead. If the head was never removed they would never assume it was a 12 porter.
I myself never knew it had 12 ports untill the manifold was removed.
The below pics are butterflies and a head from a GTS-R which has a red eccs as standard.
You are exactly right Jayson.I too had the head removed from my old red top eccs Rb20det-r and it looks exactly the same as your picture(12 ports),even though it had the 6 runners on the plenum.Cheapest power upgrade for top end power has to be to remove the butterflies.Shit job though.
Does someone have a picture of a silver top Rb20 head,i would like to see the difference.
    • Sounds good. Provided the panel is flat/level I'd be happy to start the painting process.  While you are learning, for sure you could do this. Its only paint, you can always sand it all back and start again. Its only your time and money on materials, but while you're learning, really its time and money spent on your education.  Once you know how to do this bodywork and painting, you won't want to waste your time and money on frivolous activities lol.
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
    • That's sick, thanks for that, mine has much the same mods on a 400R. I just don't have the heat exchanger yet.   Might be worth a trip down the M1 to Syndey for a tune.
    • Mate , this is the current mods list Current Mods list (Installed) RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler AMS Alpha Performance Full Race Down Pipes ECUTEK tune form TuneHouse in Sydney .(Just over 2k) The car came with HKS - Power Editor but I had it removed for the full tune. I would say if you are using the car for street diving a proper tune would be better.
