i was going to show a diy for an auto gearbox service but no one knowes how much torque to apply to the band. i will still do the DIY but there will be no pics of the band tightning
R33 GTS-t DIY to come pending some info on the band size
  • 2 months later...
page 207 has the band adjustment values for us auto guys
now keep in mind the gear box is upside down in the manual. so the nut is on the right hand side of the engine next to the zorst on the top of the gear box.
when i figure out how to get to the bolt the easy way i will let you know
the fault codes for the auto box just handy they be here
1. Have the car at normal temperature in Park with the overdrive on
2. Start the engine - the power light will go out after 2 seconds
3. Turn the ignition off
4. Move the selector to Drive (you may have to use the push button release)
5. Overdrive off
6. Wait 2 seconds, and turn the ignition on
7. Wait 2 seconds and move the selector to 2
8. Overdrive on
9. Move the selector to 1
10. Overdrive Off
11. Press the accelerator fully and release
12. Hopefully the power light will flash out a series of 10 or 11 flashes.
Here are the auto trans codes.
The sequence starts with one long flash. If everything is OK, this will be followed by ten short flashes.
Errors are indicated by a long flash in the sequence of short flashes.
1st flash longer: revolution sensor shorted or disconected
2nd flash longer: speed sensor shorted or disconected
3rd flash longer: throttle sensor shorted or disconected
4th flash longer: shift solenoid A shorted or disconected
5th flash longer: shift solenoid B shorted or disconected
6th flash longer: overrun clutch solenoid shorted or disconected
7th flash longer: lockup solenoid shorted or disconected
8th flash longer: fluid temperature sensor is disconected or the control unit power source is damaged
9th flash longer: engine revolution sensor shorted or disconected
10th flash longer: line pressure solenoid shorted or disconected
All flashes the same with no long start flash: battery voltage low, has been recently disconected or control unit has just been reconected.
Also found these codes, but I'm not sure if they are relevant;
Auto Diagnostics
Code Description
111 Inhibitor Switch
112 Vhcl Speed Sen A/T
113 A/T 1st Signal
114 A/T 2nd Signal
115 A/T 3rd Signal
116 A/T 4th Signal
118 Shift Solenoid/V A
121 Shift Solenoid/V B
123 Overrun Clutch S/V
124 Tor Conv Clutch Sv
125 Line Pressure S/V
126 Thrtl Posi Sen A/T
127 Engine Speed Sig
128 Fluid Temp Sensor
