Are you going to keep your mid ninteys R33 for the rest of your life are you? If not im sure you, like me will one day want to upgrade right? hence id want a newer import... and id want to be able to do it with a little hastle as possible...
THATS why the new scheme is a big deal.
https://www.sau.com.au/forums/topic/8881-new-import-laws/#findComment-131032
car prices will always go down.... its just the way it is... sure with the new laws the might hold for a lil bit... maybe even go up a touch... but the bottom line is pricese will always decrease...
Oh and im going to lease my next import through the business :D
hehe
I do get what your saying though.
https://www.sau.com.au/forums/topic/8881-new-import-laws/#findComment-131046
well it's a big deal for me cos i want to import a R34 GT-T in about 7-8 months. Luckily R34 compliance costs are already fairly expensive, and it won't go up too much. But i have to find a mod-free car as to avoid the extra costs of removing them all. Plus the whole process is apparently going to take longer, quite a bit longer.
don't baby our automotive industry by pratically killing off the import one. Make it easy for cars to be imported, give ppl the choice when it comes to buying a car. Let them find out there are better cars for less money, then let the car makers in australia catch up to world standards. Be pro-active rather than re-active. In the long run it will be worth it bcos australia will be producing world class cars because they were forced to catch up due to relaxed import laws.
/end bitch about government.
https://www.sau.com.au/forums/topic/8881-new-import-laws/#findComment-132698
my thoughts from another place - i signed the petition last year
Originally posted by zdeno
i dont understnd
wont the laws increase the prices of our cars??? and it wil also hold there value
i kinda like the new laws
Perhaps it will increase the resale values - but I signed it to help the guys who are trying to get a car [now]!
And what if "we" want or need to buy another car, are you happy to pay perhaps, several thousand dollars extra for what will essentially be the same car passing through different legislation [red tape]?
Some of the laws have already wiped out small business' which can be seen as good for some while bad for other's.
Good: stops the dodgy operators bringing in crap cars?
Bad: too costly for [the honest] small business to adapt / meet requirements of new RAWS?
It all depends on how you look at it i guess, maybe we don't really know what the full effects are yet?
https://www.sau.com.au/forums/topic/8881-new-import-laws/#findComment-133076
    • Thanks! Will get it looked at before winter 🥶 other than that she's a mint ride love it aye
    • FWIW a lot of the local owners that do a big build tend to have cars that are perpetually broken.
    • I just got this system but haven’t installed yet I got a Moroso sealed box (defect reasons) which will be set up same as their pic The quality is high grade, the correspondence I had with the owner (former head designer for Rockford Fosgate) was unbelievable, guiding me with what I needed. Even told me not to buy some things as it could be sorted in a different way at his loss. Just a bit of a bite with the exchange rate and don’t purchase gear in 1 hit that goes over $1,000 au, lol I forgot!
    • Thanks mate for that reply. Very helpful.    it’s a 2022 400R so would most likely lose those features as you say.     I did a quick compare of a rv37 nav and heading for sale in Japan to q50 model. I’ll pop pics below. Seems  Japan spec head into top, nav unit second below it   below pic Q50 aud delivered     differences seem to be Aus delivered has a different plug top left hand side of head unit- not sure what and where it goes.   and nav unit Japanese tv37 had an extra plug put    Again I’m really not sure what each of these differences mean!       the actual plugs on a v37 and q50 screens look identical on both screens… pics below for comparing. (One screen was is a us delivered one) but should be same gps signals etc as Australia.    If it were as simple as swapping a nav unit from q50 aud delivered im interested -just want to figure out what the missing plug is for before spending big $ on a second hand part for it to not work, and I guess with the head unit, if the band expander does the job (I got a 20mHz so should get the range I’m after) so should narrow my issue down to nav unit only.  I’d love to know what the extra cable on rv37 does and if I eliminate that part what it’ll do to the setup,    and also, if I can figure out what that head unit plug difference is, what does that cable do and where does it got can it be altered or re-plugged?! Excuse my ignorance what is ACP/AA, what does that stand for? (Apple car play? Android air play)? so If I swapped head units to save using a band expander, I’d likely lose those better features to have an oem Unit operational. Better to use a band expander and retain AirPlay options and newer version of head unit     provably best to band expand it, and focus on the nav unit. th isn’t  a big deal/ would be cool to have it working  from what I can tel we use a PAL Signal and Japan uses a NTSC signal  I don’t know if there’s a co better or if the screen only reads NTSC, or if it’s the tv module that needs replacing… no big deal don’t need it but more of a curiosity thing on that!   Thanks for the info re tyre sensors, helpful and great to know.  I was reading the online manual off Japan website and it seemed to make it sound more confusing than it is  I guess a rim replacement would require the sensors to be moved to a new rim to carry that option over?!     Thanks for the info regarding diagnostic mode. I appreciate your help mate. Trying to brainstorm here to find a solution to get as much gadgets as I can working! I plan to get my local Nissan tech to have a look too who used to be at an Infiniti dealer back in the day to see if any thing they have or idea can find a soliton. But hoping anyone here has gone down the same route to make life easier!!   i guess identifying the cable/plug differences and what they do would be a great way of finding out if the units are transferable    thanks again
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
