blitz make an aftermarket ecu called the blitz access ecu. i dont know any details on it and i havent seen much either. i dont know anyone that can tune it or connect to it via the cable interface they have. i think its like a mines chipped ecu useless unless you are best friends with a mines workshop (or in your case a blitz workshop)
https://www.sau.com.au/forums/topic/88821-blitz-computer/#findComment-1604543
ACCESS ECU
On turbo charged engines, the most common way of increasing power is to increase the boost pressure. This increases the amount of air going into the engine, and providing there is sufficient fuel to accompany the boost pressure, the resultant charge is much denser and provides more power. Standard Engine Management systems have built in boost limits, which turn the fuel injectors off if the boost rises a certain amount over standard. To remove the boost limit, an upgraded ECU needs to be fitted. This will usually allow a 30-40% increase in boost pressure with corrected fuelling for the increased boost. Increasing the boost without increasing the fuelling will cause the engine to run lean, which can be fatal for the engine. The Blitz Access computer does not rely on fooling the ECU with external clamping circuits or making sensors read differently, it properly re-programs the factory limits, and all the fuelling is adjusted accordingly. The Boost limits are raised, the speed limits are removed, the rev-limiters are raised, the timing maps optimised, and the fuelling maps are adjusted to cope with higher boost.
https://www.sau.com.au/forums/topic/88821-blitz-computer/#findComment-1604544
Sorry to hijack the topic but...
a question to add to this topic.
I just purchased an r32 with a "Blitz access" sticker on the front bumper, and was wondering if this ecu is actually in my car somewhere as a piggyback ecu. I checked where the stock ecu is and it looks to be the factory one as it says nissan on it, but was wondering that a Blitz one could be inserted somehere else in my car.
Where else should I look. thanks
https://www.sau.com.au/forums/topic/88821-blitz-computer/#findComment-1604638
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
