The car in questions intake temperature rose dramatically (bigish single turbo which was only just starting to get into its efficiency range, so that wasnt the problem) above 15psi, it just didnt seem to have the capability to scrub the heat from the air passing through. Wether this was poor internals on the runners, or a poor front end surface meaning the air didnt pass through it very well not sure.
Car is an R32 GTR which ended up making 390kw on ~23psi boost with a HKS Type R cooler and kept inlet temps nice and cool.
When you put it like that it make more sence. If the hybrid cooler was on say an rb20 with a 2530 turbo running 15psi im sure it would be fine but it would be probably be only making 200rwkw ish. I guess its probably best rating an intercooler on a power rating than a psi rating. 390kw is a lot im only guessing but the stock GTR intercooler would be probably out of its efficency level at that power too?
cheers
I have a hybird copy in my R32 and it works great! Doesn't block flow to the radiator and is very effective, after a long fast drive I touch the inlet and it is pretty warm, then touch the outlet and it is actually really cold.
Hmmmm so the original hybrid are ok then ay,hmm sounds ok but like i said i dont want to be cutting in the chassis and fan, if i go a intercooler aswell there is no way of saving the standard snorkel used with the airbox ay thats gotta go?? Is there such a thing as a direct bolt on where nothing needs to be touched and just goes on and works well????
The Blitz LM intercooler kit uses the standard route for piping from what i could find out.I too am not keen on cutting and hacking away at my car just for the sake of saving a few $. Do a search or call Autobarn who sells them. Oh and they are slightly smaller than the Hybrid cores.
Peter
the blitz uses same piping route and nothing is touched and you can retain everything stock ,the kit only comes with 2 pipes and is a very fast install say 30mins ,if that . but the thing i dont like as you cannot change your plenum ,without changing coolers. so you are comitted once you get it.
the r33 and 34 kits are the same aswell.
here are some pics. :P
http://www.blitz-uk.co.uk/2003/images/inter1.jpg
Edited by gtstcoupe
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
