Sure it's nice and even but below minimum reccomended.
Safe compression is anything between 135 ~ 180psi (as per the Nissan Japan Service Manual)
Your engine is tired.... it's had a hard life and needs a refesh.
Re-coondition the block & head, new bearings and piston rings and you should be fine... budget for new pistons just in case but I suspect you may get away without them. However if you plan on putting horsepower into this engine then I suggest you put forged pistons in. Tomei make very nice 0.5mm (20 thou if you speak to any Australian engine builder) overbore pistons for the RB25. CP Pistons are an alternative if your busget isnt that high. Also don't forget to put a 1.2mm Head Gakset in if you're goin to run higher boost.
hey all, just did a compression test on my car and was curious about the readings,
1- 120
2- 119
3- 120
4- 120
5- 119
6- 119
i would just like to know all your opinions on the condition of my engine
thanks
slo33
I got my compression test done with around 130 across all cylinders. Motor seems fine, mechanics said that was a good result.
Dont pull your engine out , it looks like you ahve a good engine there .
The comp test gauge may be reading low , who did it ? if a pro did then treir gauge is reading low and they probaly know it .
If your engine was stuffed its unlikely that it would be so even , my bet is it woul vary a lot more than that , regardless if you are loosing comp from valves or rings .
Do a leak-down test if you want to be sure .
Standard comp for rb25det is 12.2kg /cm2 (about 170-175psi ) @300rpm , limit 9.2 and difference limit between cil 1 kg/cm2 .
rb25de standard comp is 12.8 kg/cm2
rb26 dett 12kg/cm2
I wouldn't say that an engine down on compression by over 30% is a good engine. Sure the gauge may be reading low and it wouldn't be a bad idea to get a test done somewhere else, however if this is the true compression of the engine then it needs a refresh.
Also an engine doesn't have to be blown up to need a re-build. If it's had a hard life but has been serviced and looked after properly then the compression test should look like this one. If something happened like a cracked ringland or dropped valve, then 1 (or more) of the cylinders would read lower than the rest for sure.
i doubt it would be worn like that, but anyway as an example i had a compression test done for a friends car one gauge read 160psi across first few cylinders before getting jammed, grabbed another working compression gauge it read 140psi across the cylinders.
I didnt say that either , what i said was "its unlikely that a worn stuffed engine would have even compression " not imposibble though just unlikely .
Old worn engines dont have so even compression on all cilinders and that leads me to believe that it may have good comp much higher than the test .
If the true comp is 120 psi on all cil that engine would be gutless in stock form with stock or near stock boost a 6 cil bommy will kill it .
Thats the reason i suggested he does a leak-down test that will prove the state of his engine .
and my car seem to run better than most other 33's, i raced another 33 with front mount, 13psi and 3" exhaust and i beat him by car lengths ( my car just had standard shitty little side mount cooler, 11 psi and 3 " exhaust) it made 240 at the tyre spretty easy though
  • 2 years later...
Just got a compression test done today theres abit of difference in the results, but overall looks pretty healthy
Dry / Wet
1. 160 / 180
2. 160 / 170
3. 150 / 170
4. 155 / 175
5. 155 / 190
6. 160 / 180
Edited by skyzaman
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
    • Sounds good. Provided the panel is flat/level I'd be happy to start the painting process.  While you are learning, for sure you could do this. Its only paint, you can always sand it all back and start again. Its only your time and money on materials, but while you're learning, really its time and money spent on your education.  Once you know how to do this bodywork and painting, you won't want to waste your time and money on frivolous activities lol.
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
