Just had my car back on the dyno, after my latest lot of mods. Was hoping for a few more kw than the 117rwkw that my car got but at least it was a gain. Dyno was run in 3rd gear.
My car seems to running a bit lean through the mid range, so might have to invest in a fuel pressure regulator.
And it definatly looks like I need to get some bigger cams :P or more tuning or something, the power really drops off up the top end.
The next mods I'm looking at is installing an electric fan and installing a bigger throttle body.
Anyway here's my print out
Edited by skyla
https://www.sau.com.au/forums/topic/88879-my-latest-dyno-r33gts25/
Yeah I thought it was a bit funny that they ran the dyno in 3rd, don't know why they did that??? <_<
So far the mods that have been done are, exhaust 2 1/2", extractors, K&N pod filter with cold air intake, custom 3" intake pipe from the pod to the trottle body, and running an after market ECU (GTS link).
would be interesting to compare your dyno to a dyno dynamics readout with someone who has similar mods.
as i personally think that you should be pushing more power.
shouldn't it should be fine to do it in 3rd gear if they configure the dyno for 3rd? but hmm... 4th....
eug
p.s - did u retain the VVT with the GTS Link?
Eug, Yeah I'm a bit disapointed with the 117rwkw I was hoping for over 120rwkw, but it is at least a step in the right direction.
Yep it's still running the vvt with the link ecu.
Al, when the ecu was installed and tuned earlier this year it was set up with different mods to what I have now, when I changed to the custom intake and added the pod filter it obviously changed all the air/fuel ratios and the car needs to go back in for more tuning to correct this. I have been putting it off untill I have got more of my planned mods done, I have cams, throttle body and a few other bit's to be done before it goes back to the tuners.
Edited by skyla
The ECU (GTS link) I'm using is most commonly used on turbo skylines.
I'm not familiar with the Apexi power FC, but from what I have heard are better than the link ecu's. I can't see why they couldn't be used on a N/A car, although better to find someone that knows for sure.
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
