Originally posted by DJ_L3ThAL
nah its a private sale near melbourne airport (bout 15mins from me house)
opps wrong acusations! to answer some of your questions, easiest way to see if there has been any crash/panel works is to look really carefully at the paint on each and every panel.
Run your fingers over and see how smooth it is. The original paint has little rigit over it but if you see any panel with REALLY smooth paint, then it had been resprayed..
@akeenan: Wanna swap? :)
  • Replies 92
well obviously he's a car sales person and he wants to get rid of it..they are not gonna say its been smashed and in crap quality.. they will try their best to promote the car for the sale (Keep that in mind).. The dandenong place i was talking about said the same thing, but when looked carefully it had been in an accident..
Get a RACV check as some suggested..will cost you $210 but you have to take the car to their nearest Caryard as they will not come and look at it because it is an import. Take the car for 4-5 hours leave it with them and they will give you a report and gradings on the whole car. Its worth it.
hehe im stresed about the engine, i am commited now i cannot back out i have put a $2k deposit on it, from what i tested it seemed fine to me but there are things i wouldnt be able to pick out like a mechanic would, ill just get it tesated when ni get it and fix anything needed, if its real bad ill go and bash the guy :)
this isnt really off the topic but i'll tell anyhow. I was just at chadstone skateboarding and there were heaps of cops everywhere. to cut a long story short a cop came over and started asking me the usual questions anyhow he finally said did you drive here tonite and i said yes and he goes which is your car and i gave a very vague point towards my skyline and he says oh ok thats fine! and they drove off.
Guest alexR33
GRADE
AUCTION....VEHICLE CONDITION
9 under 3 months old with less than 500 km's - as new
8 under 6 months old with less than 1,000 km's - as new
7 under 1 years old with less than 10,000 km's - near new
6 under 3 years old with less than 10,000 km's - near new
5 any age with less than 50,000 km's - near perfect condition
4.5 better than grade 4 (often_grade 5_with_50,000+ km's)
4 may need very minor repair or clean
3.5 may require a few small repairs or have high km's
3 average condition for it's age, probably has some repairs needed
2 poor condition, badly rusted or in need of major repair
1 heavily modified car (sometimes_used for flood damage also)
A previous accident_repair (generally high quality, but not always)
RA very high quality accident repair or very minor accident (almost impossible to see repairs)
B large accident, poor quality accident repair or_generally very bad condition
A1 accident repaired car that is also heavily modified, or very minor accident repair
** current accident damage, still in need of repair, stolen & recovered, etc_
anyways he said it was auction grade 5,
As akeenan started to say, it is not possible that it was Grade 5. Only showroom condition - brand new cars are rated as 5. You probably are getting a nice example but definately not 5. The guy is talking crap there. Ask any reputable importer here for a run down on the gradings. Geoff @ PrestigeMotorsport has it listed on his site!
Grade 4.5 is like one or two tiny blemishes that will rub out.
FYI: I have got a 1998 build r34 gtt that was rated as a 4 with a couple of minor scratches but barely noticeable.
oops, just read the last couple of posts...
how long have grades 6 > 9 been around? Never heard of those before! No i am not a newbie either.
What is your source for this info alexR33?? just curious
that price includes 1 year registration freshly done in my name when i purchase the vehicle
If it had never been registered in Oz before then you would have to get 12 months reg as a minimum anyway. But its good that the seller "appears" to be paying for this though!
Not sure about grading 6 > 9. But from 1 - 5 is the rating the car was imported from Jap.
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
