Alan and I were only there for an hour or so - we had a ferry to catch.
Was great looking day - and the cars really do shovel down that straight.
Hope everything went well and some fun was had :)
Some pictures here:
http://www.jamezilla.com/sau/piarc/index.html
https://www.sau.com.au/forums/topic/88909-piarc-track-day-25th-sept/
I was behind this car through turn 1 and around Southern Loop.
Around Southern Loop this thing was actually quicker than me but I was as close to his ass as I could be in order to get past him before Honda. Anyways as we were punching out of the exit of Southen Loop - which for me is around 6,000rpm in 4th - so around 200km/hr - this things back stepped out and he over corrected and flew off the track towards the ocean in a farken hurry.
I went and had a chat to the guy when the session finished - the poor car had lost half the paint down the left side from stones in the gravel trap - but he was packing up all his stuff and he was heading home and he was selling the car as he'd seen his life flash before his eyes and wasn't ever going to do it again.
Otherwise it was an awesome day. All of me, Scotsman and Frank set PB's fo the track and after spending so much time recently at places like Winton and doing things like Motokhana's / Dutton it was great to remember just how fast and how scary that place is.
Cheers.
http://www.jamezilla.com/sau/piarc/images/IMG_0664.jpg
Cheers.
hmmm that's an unfortunate story.
i hope to join you guys at track days in the future
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
