These are very nice cars. Made from 1986.5 - 1993. There was an update to these models I'm not exactly sure when but it is around the 87-89 year. There is a few different models:
GA70 - 1GGTE engine. 2.0L, twin turbocharged, DOHC~210ps
MA70 - 7MGTE engine. 3.0L, single turbocharged, DOHC~230ps
JZA70 - 1JGTE engine. 2.5L twin trubocharged, DOHC~280ps
The 7MGTE engine is really a strong engine. All you will have to do is get a metal headgasket, and new head bolts and torque it down, some people tend to torque it down a little more than the specified torque. The factory torque rating was pretty shitty.
The 1GGTE engine, I had a mate who owned one of these and these are nice engines also. His was fitted with FMIC, Exhaust and a bit of boost and made 170RWHP. Internally these engines are really strong and will shine with a big single on it. There is also three different versions of this engine, the GEN 1 came with a water to air intercooler. GEN 2 ran more boost and an air to air intercooler. The GEN 3 engine ran more boost again and a more agressive tune, also an air to air intercooler.
The 1JZGTE engine, well these engines just have a reputation for themselves. I myself have owned two 1JZ powered vehicles. A JZA70 R and a soarer. The JZA70 R is the lightest of the supra's weghing in at 1550kg. There is other models which will weigh up to 1700kg with seat warmers, fully electric seat and stuff like that. The R supra came with bilstein shocks, momo steering wheel and knob, and also recaro seats as standard. I was very happy with my JZA70 R, it was drifted and held up to everything I could throw at it. The suspension was a bit soft for drift but as an everyday car it will be fine.
I hope this helps.
Adam
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
