Item: R33 GTS-T M-Spec Fine Example Of A Very Well Looked After Skyline..
Details: Genuine 73,000km's on on the clock Re-built only 5000km's ago. Have Reciepts For All Work Done Over 15k worth in performance parts alone..
Note front bar not sitting streight as this was just put on there for the pics about a month ago. I now have a brand new bar painted and ready to go on just before it is sold so there is no imperfections (chipps etc)on it when its sold.
Price And Payment Conditions: 23k Open to any reasonable offer even a trade on cheap runabout
Enigine Internals Consist Of:
- Aries Oversize Forged Pistons
- Aries Molly Piston Rings & Barings
- Shot Peened RB25 Conrods
- Crank X-Rayed, Polished & Balanced
- Head Has Stainless Valves 30mm Exhaust 34.5mm Inlet
- Three Angled, Cut Vavle Seats
- Ported Polished, Flow Tested & Manifold Matched For Optimum Flow
- 600Hp Rated Copper Head Gasket
- N1 Oil & Water Pumps
- New Timing Belt & Tensioners
Engine Externals & Bay:
- Deatailed In Blue Print
- 6" Cold Air Induction System
- Simota Heat Sheilded POD
- Straight Pipe From POD To Turbo (Non Restrictive)
- Custom Turbo Set Up High Flowed T3 Front VG30 Rear, Boosting 14Psi
- RB20 Waste Gate Actuator
- Monster Hybrid FMIC & Piping
- Polished Throttle Body
- Choice Of Turbosmart Super Sonic Or GFB Stealth FX BOV
- 3" Mandrel exhaust From Turbo
- 3" High Flow Cat Into 4" Apexi Cannon
Drive line:
- Exedy Racing Twin Plate Clutch & Pressure plate
- Lightened & Balanced Fly Wheel
Exterior:
- 400r Front & Rear Body Kit With GTR Sides & Spoiler
- 17" Import Rims With New Rubber
- Professionally Lowered Suspension
Interior:
- Apexi Turbo Timer
- Auto Meter 5" Monster Tacho
- Auto Meter 2.5" Phantom Boost Gauge
- Four Point Alarm & Immobiliser
- Blue Neons Front & Rear
Ice:
- Pioneer "04" Head Unit With Sub Controller
- Pioneer Splits In Front & Rear
- Comp Bandpass Boxed 12" sub
- Controlled By 1000 Watt Boss Audio Amp
Driver Comforts:
- Sun Roof
- Climate Control
- Electric Windows, Mirrors Etc
- Driver & Passenger Air Bag
- Power Steering
Contact Details:
0409834514 or Email Me At [email protected]
More Pics On Enqiury.
https://www.sau.com.au/forums/topic/88983-mint-r33-gtst-m-spec/
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
