Item: R33 GTS-T M-Spec Fine Example Of A Very Well Looked After Skyline..
Details: Genuine 73,000km's on on the clock Re-built only 5000km's ago. Have Reciepts For All Work Done Over 15k worth in performance parts alone..
Note front bar not sitting streight as this was just put on there for the pics about a month ago. I now have a brand new bar painted and ready to go on just before it is sold so there is no imperfections (chipps etc)on it when its sold.
Price And Payment Conditions: 23k Open to any reasonable offer even a trade on cheap runabout
Enigine Internals Consist Of:
- Aries Oversize Forged Pistons
- Aries Molly Piston Rings & Barings
- Shot Peened RB25 Conrods
- Crank X-Rayed, Polished & Balanced
- Head Has Stainless Valves 30mm Exhaust 34.5mm Inlet
- Three Angled, Cut Vavle Seats
- Ported Polished, Flow Tested & Manifold Matched For Optimum Flow
- 600Hp Rated Copper Head Gasket
- N1 Oil & Water Pumps
- New Timing Belt & Tensioners
Engine Externals & Bay:
- Deatailed In Blue Print
- 6" Cold Air Induction System
- Simota Heat Sheilded POD
- Straight Pipe From POD To Turbo (Non Restrictive)
- Custom Turbo Set Up High Flowed T3 Front VG30 Rear, Boosting 14Psi
- RB20 Waste Gate Actuator
- Monster Hybrid FMIC & Piping
- Polished Throttle Body
- Choice Of Turbosmart Super Sonic Or GFB Stealth FX BOV
- 3" Mandrel exhaust From Turbo
- 3" High Flow Cat Into 4" Apexi Cannon
Drive line:
- Exedy Racing Twin Plate Clutch & Pressure plate
- Lightened & Balanced Fly Wheel
Exterior:
- 400r Front & Rear Body Kit With GTR Sides & Spoiler
- 17" Import Rims With New Rubber
- Professionally Lowered Suspension
Interior:
- Apexi Turbo Timer
- Auto Meter 5" Monster Tacho
- Auto Meter 2.5" Phantom Boost Gauge
- Four Point Alarm & Immobiliser
- Blue Neons Front & Rear
Ice:
- Pioneer "04" Head Unit With Sub Controller
- Pioneer Splits In Front & Rear
- Comp Bandpass Boxed 12" sub
- Controlled By 1000 Watt Boss Audio Amp
Driver Comforts:
- Sun Roof
- Climate Control
- Electric Windows, Mirrors Etc
- Driver & Passenger Air Bag
- Power Steering
Contact Details:
0409834514 or Email Me At [email protected]
More Pics On Enqiury.
https://www.sau.com.au/forums/topic/88983-mint-r33-gtst-m-spec/
    • Welcome. This is not really true. We have a whole forum here just for the NA shitboxen. And they are not very different from the turbo shitboxen. Just weaker brakes and gearboxes, and no LSD, for the most part.
    • I'm pretty sure it has an 040 in it @Duncan Also reading up, that turbo should top out at 250 as you first thought. It will be interesting to see how early it chokes due to the changes in the head too
    • Yeah confirmed they are Nismo 555s, found the boxes in the spares with the factory injectors in. Yeah the AAC has been relocated to allow reuse of the factory brake booster line, and yes confirmed it has a 1 way valve in it. Unfortunately the one on the car is cracked, I'll need to replace it. Pretty sure I've got all the AAC plumbing correct in my previous post, but I am going to source some new fittings with 90o angles to help with the hose routing and also one really specific moulded shape for the AAC intake to cold start hose (will raid the back of our local repco when I get a chance and work out some combo that works) One of the big things I learned in the GTR is you need to be able to get your hands all around the bay when something goes wrong. I've done a bunch of re-routing now and it should be much more practical now. Also got the BOV mount re TIG-ed by the local engineering shop so that should be good to go now. Never got to the fuel pump because of some life stuff today, but will pull it to confirm it is suitable for 300rwkw when I get a chance
    • Hello everyone, I am from Malta and have recently bought myself a fully stock 1992 Nissan Skyline GTS. It has the RB20DE engine and thus is NA. Unfortunately, not a lot of information can be found online related to the GTS, unlike the information for GTS-T and GTR variants. Apart of the Skyline, I also got a 1984 Porsche 924 2.0l NA and a 2002 Renault Clio 1.5DCi for everyday use. Excited to be apart of the community and perhaps get better information on cars such as the GTS.
    • The fuel pump bracket just slides straight up.  Below is a pic I stole off a site. But basically put hand in for fuel pump, wiggle it all about a bit while pulling up.
