SOLD
Hey,
I'm with much regret going to announce my car up for sale. I'll say firstly that it's not available straight away nor will be for a few weeks at LEAST.
It's a JUNE 1994 R32 GTR, silver in colour. Plates are GTR032 and rego'd till april 06. It has been in Australia since late 2001, first owner in Aus was in melbourne and barely drove it. I bought it off him (SAU member) in early 2003 with just on 50,000km's on the clock and very very stock. Very hard to say if km's are genuine, I believe they are to be close at worst. The interior was spotless, carpets hardly worn etc.
The car currently has 106000km's, good condition and a fair range of mods including..
HKS GTSS turbo's (only 5000km's old)
MINES Dump pipes
Brand New EXEDY clutch
HKS 'TOP SECRET' Cam gears
APEXi Power FC
TRUST Clear cam cover
GREDDY Timing Belt
N1 Waterpump
HKS Front Pipes
HI-Flow cat
TRUST PE II cat back exhaust
APEXI Pod Filters
TRUST Profec B Boost Controller
TOMEI Intake manifold gasket kit
NISMO Oil and radiator caps
BLITZ Upper radiator hose
DBA 4000 Rotors
RB74 pads
May sell separately to the highest bidder
**WORK TERMIST 18 x 9.5" rims (tyres are very worn at the minute)**
Stock GTR rims have Falken Semi slicks (5000km's old and only street use)
TEIN TYPE FLEX Coil overs
NISMO Front & standard skyline rear strut braces
NOLTEC Font upper control arm bushes
WHITELINE Radius Rod Bushes
WHITELINE Pineapples
NISMO Urethane Shift Knob
Clarion CD Player
BOSTON front splits & Pioneer rear 6" speakers
HKS Boost & Temp gauges
APEXI Rev Speed Meter
Tinted Windows
Car has recently been dyno'd. Managed 275rwkw's at 1.1 bar.
There is plenty of other parts that have been replaced/modified like..
All new bearing and associated tensioners when timing belt got replaced. Heaps of hoses and clamps in engine bay replaced. Complete new gasket kit on turbo side of engine as well as TOMEI intake kit. When engine came out for new turbo's it was obvious the welsh plugs had been changed at some point since the car had been in Australia. Clutch slave cyclinder replaced. Nismo engine mount. Radiator top tank replaced. R34 GTR injectors. Cam covers painted. Thermostat replaced. I have a 3" cat replacement pipe which runs from rear of front pipes to flange at rear diff, eliminating cat and centre muffler. Most of the car has been repainted, everything except roof.
I have receipts for pretty much every dollar i've spent on it. :D and stil have numerous stock parts like the airbox, shift knob..
As like most GTR's its been quite a story of owning it. I love driving it but my reason for selling is im moving out of home soon and potentially starting my own business and keeping the car just isn't financially viable unfortunately.
Im after around 30k ono for the car, rims and all the spares.
Email [email protected]
Here's the photos I got when I first enquired about buying the car..
more pics in gallery
https://www.sau.com.au/forums/topic/88984-1994-r32-gtr/
Are you selling it with the power fc???? do you have any current photos of the interior
yep selling it with power FC, forgot to add it to the list. It's updated now. I'll give the inside a vacuum and get some interior pics posted up tonight.
https://www.sau.com.au/forums/topic/88984-1994-r32-gtr/#findComment-1608827
If you estimate the car had only 50,000kms on it when you bought it how come the turbos were worn out?
Even with a 100,000kms on it shouldnt the turbos be pulling hard still?
I have seen your car in the flesh and its one of the most tidy R32's going around. GL with the sale dude.
https://www.sau.com.au/forums/topic/88984-1994-r32-gtr/#findComment-1647308
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
