Hey guys, i have an issue with my r33 gtst. It is boosting all over the joint at the moment. It has a t61, hks ext wastegate and hks electronic boost controller. What is happening is when i put it on high boost (19psi) it boosts up to it then drops off to 13-14psi then back up to 19 then down and so forth. Its holdin 19psi for about a second if that and then drops and is back up again within a second or 2 again. its not a sharp spike or anything, more of a rolling type boost problem. It did do it when i bought the car, i put it on high boost and it did it so i decided not to use high again untill i got it tuned. Besciani's tuned it for me and one of the problems he found was that it wouldn't boost above 14psi so he checked and the wastegate spring was old and stuffed. Not having another 14psi hks spring he decided to put a turbosmart 7psi in as well as the original hks one, therfore it now has 2 springs in it. This fixed the problem and boost went straight back up to 19psi on high boost, all was good.
Now a month later, that same problem has come back. Does it sound like maybe the hks spring has compressed even more due to more pressure on it? or maybe the 2 springs are entangled with each other? As i'm not sure if the wastegate spring was even the problem the first time (could have been tuning issue or something else?) im not sure where else to look. I have ordered a spring for it but thought i'd maybe look at other avenue's while i wait for the spring. Does anyone else know what else it could possibly be, or does this sound like its definitely the wastegate spring not holding again?
Thanks for reading and i hope i make sense!!!
Cheers
Danny
https://www.sau.com.au/forums/topic/88990-boost-issue-wastegate-spring/
If you already knew the spring was stuffed i certainly wouldnt have been using it in combo with another.
Its ok to run a few. The was turbosmart ones are now you can get a small or a large one.
so you can slap a big 7psi + small 7psi to make 14psi.
Or you can get a big 14 psi spring to start and put smaller in the middle.
All about flexibility.
Replace the sping first mate, then go from there. Should never have put a crook part back in!
Only even going to cause more problems
hmmm, very true. It was something we both decided to do, as i'd driven 2 hours for the dyno tune, and then when it wouldn't hold boost we had the options of driving home and going back another day, or pop the other spring they had there in and see if that worked. Guess with 280kw i was more interested in showin up gen3's and xr6/8's than fixing the bandaid we'd put on! lol
So i take it that it does sound like a wastegate spring related issue?
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
