hey all
got my car dynoed a few weeks back but haven't had time to post up the sheet yet.
thanks to paul from hunter thomas automotive in newcastle who did an awesome job, i was hoping for about 200ish but 218 is awesome :D:D:(:D;)
mods r as follows
FMIC
fuel pump & reg
PFC
AVCR
HD Clutch
still running stock injectors, air intake, AFM, and everything else which hasn't been changed
https://www.sau.com.au/forums/topic/89010-2187-rwkw-on-stock-turbo/
sard FPR, unsure which model. the lower of the 2
running a little over 1 bar, having been using it day in day out so far without problem.....touchwood
yes, good looking AFR curve
injectors hit about 92% duty cycle
using stock air intake
exhaust yeah sorry 3" turbo back
what reg you running? how much boost? is it a safe tune? what duty cycle are the injectors operating at? pod filter? exhaust (cat-back)?  thanks.
From those figures I believe
- 12PSI
- Stock rock ECU
- Turbo back exhaust (bashed out cat? :D )
yer? correct me if I'm wrong
Oh dear.........let's do some numbers.........
Standard injectors are 370 cc's
92% = 340 cc's
340 cc's in a 6 cylinder = 340 bhp
340 bhp = 254 kw
less 60 kw for losses in an R33GTST = 194 rwkw
218 rwkw would =12% increase in fuel flow
12% increase in fuel flow = ~40% increase in fuel pressure
standard fuel pressure is 36-38 psi, so +40% = 53 psi (above boost)
53 psi plus 1 bar boost = ~68 psi
I sure as hell hope you are not running 68 psi through the standard fuel lines and clamps, that is asking for trouble.
:D cheers :D
PS; 1 bar on the standard turbo, tick.....tick......
just curious how this figure was derived.
pretty run of the mill mate, search around. Lots of info.
Drivetrain loss is lies between 25-30% from the motor the the rear wheels.
SK have used approx 25% in his calc of 60kw
Cheers
Oh. and yeah, turbo wont last @ 14psi, not thats it'll be doing much above 10/12 anyhow.
also, above 1 bar equals a nice amount of hot air being rammed into your engine.
I'd be keeping an eye on that knock sensor..
and and for your info, I am running 11psi, and got 210rwkw. Why so much more boost just to get a measly 8 rwkw, and risk blowing your motor \ clutch \ turbo ?
dont mean to take over this thread, but just a quick question.. i got my car on the dyno today to see how much i got from the new apexi cat-back.. its a series 1 r33 GTS-T AUTO with just an apexi power intake kit and an apexi cat-back echaust.. it made 155 RWKW, does any one know if thats any good considering its an auto and pretty much stock?.. what would that be KW @ flywheel instead @ the wheels?... and does any one know how much KW a stock standard auto R33 has?.. thanks for the help.
