  • Replies 47
Dont think it shits itself i ran it to 14psi and held
have u noticed your probably not making any more power than running 11psi ..
hahahahahahahah there's a difference between u think and u know!
keep thinking and keep running it at 14psi and see what happens...lol :lol: :lol:
I dont always run it at 14 if thats what you think during the day i run it at .360 and night at .600. i got told the limit is 14psi
11psi is the limit for the stock turbo anything higher than this and u will see a exhaust wheel out the backend...also there is not much to be had above 11psi ...u might as well use it for a hairdryer.
:P:P:D
everyone has a different figure in mind.
I had one running at 12psi let go after a few weeks
I had another i was running at 16psi for almost a year in my car even drifted it like that and it never broke
Now I wouldnt push it past 13psi. after that it is just pushing hot air anyway.
infected flow
My brother was running up to 16 psi sometimes with his r33gtst which had an r34 turbo put on it. he gave it heaps on full boost and it held together. What are you basing this this 11psi figure on???
hahaha and i bet it did nothing at 16psi !
and through r & d !
hmmmmmmm since im sick of explaining do a search !
and geezzzz maybe because there's 4 people i know that have blown them running 12psi exhaust wheel out the exhaust (and yet i told them its only good for 11psi )
and how long did it hold together....?
and yes the r34gtt turbo is only good for 11psi thats its limit ...
infected
yeah well i also have an r34gtt and its boosting slightly below the +1 on the standard boost gauge, which would mean it is boosting at roughly 12-13 psi?? and the turbo hasn't let go yet.
i suggest you do some more r & d before you pretend like you are an expert
Heat and torque loading kills the ceramic turbine, not boost on its own. I have seen 6 Skylines with ceramic in the cat disease at 12 psi or more. But the people that own these 6 Skylines actually USED the 12 psi for more than 5 minutes continuously at higher than 5,000 rpm. Not 12 psi/>5,000 rpm for a few seconds, then doddle around for a month or so.
So you can run 50 psi if you like, just don't do it for very long, not long enough for the heat to build up. That's why some people have problems at 12 psi and some people don't. The people that have problems are actually using the power that the 12 psi facilitates. The people that don't have problems at 12 psi doddle around most of the time and get no benefit from the 12 psi. So they might as well not bother.
it wont let go at 12
I will be in Adelaide next month, I will bet you that at >12 psi I can kill your ceramic turbine in less than 10 minutes. Wanna test it?
:O cheers :)
hahahahahaha
yeah sure why not sydneykid then when you have finished blowing my turbo for me you can come back to my house and f**k my sister.
hahahahahaha
funny guy, but well put i must say. hahahahha
maybe thats why the turbo hasn't blown yet because i dont hold it at 12 or 16 psi for 5 mins straight. Realisticly when are you going to hold it on boost for that long with normal driving?? unless you are on a dyno or on an autobahn its not going to happen.
