Hey just wondering if anyone here knows what's going on with my brother's car. He's recently had a Power FC and a Bosch 044 fitted into his '95 RZ Supra. The other day we jacked up the car to remove the wheels. After we'd put the wheels back on and took it for a drive, we'd noticed that the fuel pump was making a loud noise. The car suddenly lost power and wouldn't move. We later found out that by jacking up the car, we'd knocked the fuel pump around and it ran out of petrol (he had very little in there to begin with). We've since fixed the pump, but now the car still loses all power. It doesn't happen all the time, just at random. Anyone had problems like this before?
"Games don't affect people. If Pacman affected us as kids, we'd all be running around in darkened rooms munching on pills and listening to repetitive music."
https://www.sau.com.au/forums/topic/89071-power-fc-cutting-out/
If it was a fuel issue, wouldn't the car sort of 'chug' before coming to a stop? The car just loses all power, it's like he's turned off the ignition while driving. He was driving on the freeway the other day, and every 100m the car would just die. Not good! Faulty wiring of the Power FC perhaps? We had a look at the installation though but couldn't find anything wrong with it.
As Beer Baron said id be looking at the fuel pump, they hate sucking dry air and usually stuff up pretty quickly. And yes if its the fuel pump failing it will cause the car to die on the spot as fuel flow to the rail will suddenly stop.
Take it to a mechanics and get the fuel rail pressure tested. If the pressure drops just before the car dies, you need a new fuel pump.
Thanks guys, I'll tell him that. He won't like it though if he has to buy a new fuel pump; he paid about $570 for that 044 at 'local workshop prices'.
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
