Ok, few questions I have been meaning to ask for a while.
My turbo has started making a 'shuttering' induction noise. So instead of the normal smooth sounding induction its lumpy sounding, like its not spooling smoothly at all. You cant feel it doing anything different (apart from the other problem, below) but you can hear it spooling strangely. The other problem is that it *feels* like I still have the standard dual stage boost control when I have replaced the BC with an AVCR. I dont seem to get much boost at all until right on 5000RPM. This happens regardless of what boost level I have the AVCR set to (standard, 0.6 Bar or 0.8Bar - usually driven on standard). I am almost hoping its dead as thats my excuse to the wife to get GCG to rebuild the sucker. But, that pushes my manual conversion back another month or 2. :P
Second quick question, The RSFour V has the V-Spec active rear diff, right? Thats why I get the clunkiness in reverse at lock? Or occasionally in gear at lock. Doesn't happen regularly. Just making sure.
Oh, and SK (only asking you as you seem to have more expereience in this area), from a SITC, Nismo FPR and the Jaycar fuel computer, can I expect much better fuel economy?
Thanks guys
Christian
https://www.sau.com.au/forums/topic/89079-is-my-turbo-dead/
I hope all turns out for the best PranK. Go the GCG.... ! :O You dont 'need' a manual, being a tall fella and all that! (there's no way in hell Id be able to drive the Stagea as a manual, being over 2metres tall).
Ive got a brand new Apexi SITC and the Nismo FPR, and already have a SAFC tuned, etc etc.
Will let you know how fuel economy goes when I have everything retuned for the SITC, FPR, fuel pump, fuel lines, Z32 AFM, etc.
Probably not for another month or so (just waiting on a price from the workshop who'll do the work for me, including retuning the SAFC). I was going to up it to 11psi, but upon reading this thread, I dont think I will!!! :P (dual stage ebc, tuned at 7 & 10psi)
Brendan
Edited by bwilkeson
https://www.sau.com.au/forums/topic/89079-is-my-turbo-dead/#findComment-1608878
I had a really bad sputtering coming from my turbo for a whlie, then it would revert to stock-like feeling of boosting, as in it had none. it turns out my boost controller had adjusted itself and was spiking really badly. i just had to turn the boost down and it's fine now. i don't know if that's similar to your problem, but it's the cheapest one i can think of
https://www.sau.com.au/forums/topic/89079-is-my-turbo-dead/#findComment-1608902
What happend to me when i installed my EBC was this
I set my map to go like this (just an idea) (high number, more limited boost)
500 - 0
1000 - 0
1500 - 0
2000 - 0
2500 - 60
3000(full boost) - 70
What i found is that when i cruised at near constant RPM, the load points would flick between 0 and 60. This would make my boost shutter and feel almost as if the rev limiter is going off....
So i made the boost limiting curve more smooth, and i now no longer have this problem.
Prank, as for a manual conversion, its not as expensive as you may think. Without interior parts, ive managed to pick up the following
r33 gear box - 850
GTST master cyl/slave cyl/clutch pedal box/brake pedal box - 350
GTST handbrake (still to buy) ~50
Clutch - what ever your budget is, ill spend around 1000-1300 for a big single
PFC - 960 in group buy on SAU
Labour - 700
PFC tune - 250
So, its pretty standard after that for the install but i am yet to do it for another month or so (need to get PFC)
For putting the PFC in, use a GTST plug and make an adaptor or re-plug the engine harness to suit GTST PFC plug (which is what im doing)
Interior parts, ill work that out after i am driving around a manual. I dont mind that special ghetto look :P
https://www.sau.com.au/forums/topic/89079-is-my-turbo-dead/#findComment-1608983
My turbo has started making a 'shuttering' induction noise. So instead of the normal smooth sounding induction its lumpy sounding, like its not spooling smoothly at all. You cant feel it doing anything different (apart from the other problem, below) but you can hear it spooling strangely. The other problem is that it *feels* like I still have the standard dual stage boost control when I have replaced the BC with an AVCR. I dont seem to get much boost at all until right on 5000RPM. This happens regardless of what boost level I have the AVCR set to (standard, 0.6 Bar or 0.8Bar - usually driven on standard). I am almost hoping its dead as thats my excuse to the wife to get GCG to rebuild the sucker. But, that pushes my manual conversion back another month or 2. :)
Thanks guys
Christian
Wow, lots of questions;
1. Sounds like a boost controller problem, try reverting to standard plumbing and see if the noise persists.
2. Yep, ours gets the cluckiness in reverse most times, but it comes from the front not the rear. I will have another look, tomorrow while I am installing to the Whiteline rear springs. But I am sure ours has a "normal" rear diff, no extra stuff hanging off it.
3. The DFA on its own gave me a 10% improvement in fuel economy. That's with the standard exhaust, I reckon there is another 5% in upgrading it (turbo back). Once I finish the exhaust I will give the SITC a quick tune, it's installed, just not tuned yet.
:) cheers :)
https://www.sau.com.au/forums/topic/89079-is-my-turbo-dead/#findComment-1609029
:) cheers :)
Hmm, I dont have any clunkiness (that Ive come across as yet) on my Stagea - must be one of the lucky onse.
With the SITC, SK, how long do you expect tuning to take? Do you do it on the dyno, etc?
Im going to take my Z32AFM, SITC, & Nismo regulator to the workshop, have it all installed along with highpressure fuel lines and amp up the power to the fuelpump... how long do you reckon it might take to tune the SITC and retune the SAFC?
Also, is it better to highflow the standard turbo currently on the car (in good condition, I think), ot highflow a rebuilt R33 turbo?
Cheers, Brendan :(
https://www.sau.com.au/forums/topic/89079-is-my-turbo-dead/#findComment-1609605
1. Hmm, I dont have any clunkiness (that Ive come across as yet) on my Stagea - must be one of the lucky onse.
2. With the SITC, SK, how long do you expect tuning to take?
3. Do you do it on the dyno, etc?
4. Im going to take my Z32AFM, SITC, & Nismo regulator to the workshop, have it all installed along with highpressure fuel lines and amp up the power to the fuelpump... how long do you reckon it might take to tune the SITC and retune the SAFC?
5. Also, is it better to highflow the standard turbo currently on the car (in good condition, I think), ot highflow a rebuilt R33 turbo?
Cheers, Brendan :(
Hi Brendan, suggestion follow;
1. It only happens when you have full lock on and reversing.
2. Just the SITC on its own should take a few minutes, it's only 5 load points. The time may be consumed in retuning the SAFC. Because you can do some retarding with the SITC to offset some of the unwanted advancing that happens when you reduce the AFM voltages to get the A/F ratios where you want them. It ends up being a bit of a go round, fine tune one, then the other. But I can't see it taking more than an hour.
3. No you could tune the SITC on the road by listening for pre-igntion, but it is a bit hard as you end up doing warp speed soemtimes to get enough load. Best done on the dyno.
4. Retuning the SAFC for the Z32 AFM is a bitch, basically you have to start again from scratch as the voltage ramps are totally different. So however long it took to do the original tune plus a bit as it will require some more adjustment than the standard AFM.
5. No diffference, everything that wears is replaced, so it doesn't matter what condition the turbo you have high flowed is in. Its a bit more convenient as you can swap them over easily in a few hours. Otheriwse you will have to wait a few days (no car) while yours is high flowed.
Hope that answered your questions
:) cheers :)
https://www.sau.com.au/forums/topic/89079-is-my-turbo-dead/#findComment-1609980
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
