i got a r33 gtst with fmic, cat back exhaust and a pod filter
im lucky to get more than 250 on afull tank of vortex 98 driving slow!!!
ive changed the o2 sensor but that doesnt seem to have worked :S
also bought a new afm
any ideas???
I had a similar prob where my car was just sculling fuel, its cos of the standard computer. I got a fuel controller and had it tuned and it fixed the prob, now a full tank lasts me ages. It not only uses less fuel but i get more power aswell due to leaning out of the mixtures. Get an SAFC or PFC or similar this will fix your prob. :(
yeha the fuel adjuster seem the way i wnat to go, but 250 is wayyy to low :S im certain that my afm is good, and i changed the o2 sensor!
im worried if i tuen it and reduce the ratios the computer will do somehting stupid like run lean and ping!!!
but the car aint worth having if i get 230-260, thats trash! a pushrod v8 gets better than that! and vortex 98 is 98ron so it should be similar to bp ultimate and the car sems to run rich.
might be a stuffed cpu but its all good. im almost finished building a jaycar fuel adjustor and will install and dyno it soon. ill keep u guys upto date with what happens
Vortex is 95 octane
any ideas???
Try cleaning the hot wire in the inlet just down from your pod. The oil that you put on the pod[ K&N or my Unifilter] coats the hotwire and insulates it so the ecu thinks it needs to pour the fuel in.I use CO contact cleaner and gently use a cotton bud to do it.
It shouldnt be running so rich and using so much fuel. Just buying a fuel adjuster is masking the actual problem. Have you tried an ECU reset? You should also try an ECU diagnostic as one of your sensors may be playing up.
thats exactly what im thinking!! i dont wnat to amsk the problem cause itll come back to haunt me!
dude what is the hotwire ur talking about? cheers
Bazz. The hot wire tells the ecu how much air is flowing through the metering system.If you take the pod off [there is probably a mesh cover in there]and look down the induction tube you will see a brass spigot with a large slot cut in it. This brass spigot comes through the side of the tube and a six or seven pin plug goes off into the wiring loom. The way hotwires work is there is a current ,known to the ecu through the small resistance wire. As more air flows over the hotwire it cools therefore to keep the known resistance more power is sent to the hotwire.This is how your ecu knows how much air is flowing through the motor, so therefore the ecu changes the fuelling[pulsewidth and duration] to suit. The lambda sensor does a similar job in the exhaust.
ohhhhhhhhhhhhhh the hotwire in the afm!!!!! yeha dude i did that already. i did a once oiver on the o2 sensor wire anmd some of it looked like it was in bad nic, so i changed it and wala!!! did 100km on first qurater :)
so basically guys if ur running rich this is what worked for me
1)reset the cpu
2) change o2 sensor (or if its fairly new clean it with contact cleaner ~$7 at dicksmith) and reset again
2) make sure all the elads to the o2 sensor are healthy!
3) clean the AFM with contact cleaner and reset again
4) use bp ultimate :O
this worked for me. my next step would have been to put the car on the dyno to see that the other sensors are healthy and that the cpu maps are good!
anyways thanx for all the help
cheers
Edited by bazz
i got the o2 sensor from repco. the direct fit (with the EF plug) cost me $82. i used a pipe socket to remove it, or you could do it with a spanner (21 or 22 cant remeber exactly). i did it myself (and i know nothing about cars). the brand they gave me was ACA. it had a blue wire and 2 black. using clip connectors i put the blue to the big brown wire on the car (r33 93model) and the other 2 are just heat so doesnt matter. then u reset ur cpu and its all good
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
    • Mate, I take this thread in random directions on occasion myself, so no foul I'm a old fan of MCM anyway, I like their banter, and enjoy most of the stuff they do
    • Something strange is happening. I didn't touch the car since we last spoke on the forums. Yesterday was the first day of good weather, so i took it out for about 2 hours. It started up on first crank every time about 5 times total. I literally didn't do anything to do the car.
    • I purchased this one. Very well priced and works great. I was rough with it to see if it will last and had no issues.  Teslong Two-Way Articulating Borescope with Light, Industrial Endoscope Inspection Camera with Articulated Probe, Flexible Mechanic Fiber Optic Snake Scope Cam for Wall Automotive Engine Inspect-5FT : Amazon.ca: Industrial & Scientific
