hey man maby there blowing off for a reason?
when i put my cooler in and took my afta market bov out, the pipes blew off on boost, too much presure!
i thought my stock bov was fine but lookd at it and it was blockd, fixd it and the piping never comes off
does ur car flutter heaps loud?
I can think of a number of ways to stop piping coming off and if your BOV is OK you might try
1. longer pipe sleeve and two clamps
2. roll a ridge in the pipe so the clamp has a bite point
3. Run a bead of weld around pipe as in 2
4. Bush mech a self tapper through both LOL
Good luck and what Boost R U running?
there are also a better style of hose clamp you can use, they use a big bolt to hold the two sides of clamp together they can be done up really tight. Tridon are one brand that make em, get the from Pirtek
but you also need a good lip on the pipe to hold it, a lot of cheap aftermarket ones dont bother with the lip.
Thanks for all the replies, after thinking a bit more abotu it I don't think it would be my BOV being too tight (don't have a stock BOV) because they are blowing off while under acceleration/boost, not when realeasing air.
Welding a lip onto the pipe sounds like a good idea, and I already have a few of the good clamps, so I will get a few more where needed and see how I go. Boost atm has been either 12.5 or 16Psi
its got nothing to do with a BOV.
its the piping/clamps only.
You probably need more lip welded onto the edges of each pipe to help the clamp hold on where the hose meets.
Also install better clamps on those points at the same time.
You can get the clamps from Hose Fitting places, Enzed, Purple Pig... and other specialist stores.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
