  • Replies 43
paulr33 - you can keep it as its not worth the transport troubles. As long as you dont throw it out. (the minute you throw it out you will need it!)
qik32 - what and where exactly is the harmonic balancer - i will have one. is it the main center pulley. just to clarify i have one, i would not know how to check what condition it is in
cheers
shaun
armbrusb - i do not have the airbox - but i have a afm green sticker - unsure of condition - i have someone interested at the moment local - but if they dont want it - i can send it up to sydney - you pay postage but you can have it for free until you find out if it works or not.
shaun
ill le tyou knopw
  • 3 weeks later...
  • 2 months later...
