hey i installed a boost gage today and it seems to read higher then the stock boost gage? do u guys have the same problem?
my stock 1 is just under 7+
and the new 1 is 0.7 bar
i duno if its reading rite? and isnt 0.7 a little high? i havnt boosted the car up at all all its got is a Pod, cat back and a bov?
also whats standard boost for an R32 GTS-T?
thanks!
https://www.sau.com.au/forums/topic/89244-boost-difernt-readings/
Just under +7 as in just under the line or the actual print +7?
If just under the print or .7bar (10.15psi) sounds right.
My stock boost with a full 3" is 11psi.
Some with a 3.5" have seen 12psi.
Edited by Cubes
I had a friend install it on his VL, it would only hold 10-11psi or so, stock boost on those are around 7.
I'm putting the turbo on tomorrow with the bleeder, I suspect it will tail off at high rpm as my dump pipe is not the best.
I'll be getting a split dump made up when I drop the xr6 turbo on around xmas. I've got a vg30det bb ceramic turbo going on to keep me happy until then. :huh:
It should only need around 11psi to make ~200rwkw.
yeah cuz im going to buy 1 u recon 12psi is safe for me?? and u rekon my new boost gage would be reading corect then ay? if so whats 12 PSI in BAR?
and how much was your vg30det bb ceramic turo =P
I picked up the vg30det turbo for $300 or was it $350.. :P It was some time ago.
I wouldn't put a VG30 turbo on a RB20DET, I've done it in the past and it was a bad match. The turbine housing is too large for the little compressor.
A RB25 turbo is a much better match to the RB20DET, it has a slightly larger compressor wheel than the vg30det turbo and a slightly smaller turbine housing. On small motors you want to keep the turbine housing as small as you can.
The VG30det turbo will make the same power as the rb25 turbo BUT there will be less area under the curve on a small motor.
The RB25 turbo vs the vg30det turbo on a RB30DET, the vg30det will have more area under the curve as the motor will rev harder and not flatten out at the top end. as much. :)
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
