  • 4 weeks later...
  • Replies 80
WTB !! Wanted to buy, R32 sedan.
For drivetrain conversion, so engine/gearbox condition is unimportant.
I'd prefer something registered or registerable, but will consider track only chassis as well.
PM me if you've got something.
FS:
Stock Cefiro drivers seat
Looking for $50 + postage to get this thing out of my garage. Has been sitting around since i got the car and is in perfect condition (with rail).
In melb but can post interstate. Got a quote for ~$70 to SA when someone asked me about it.
:D
sabelt 4 point harness 1994 manufactured... really good nick with sabelt shoulder pads $100 firm suit all cars pretty much
trust oil filter sandwich block with tapped sensor holes $100 firm suit sr/rb/ca
rb20det t3 turbo in very good nick no leak, shaft play is at a very minimal - normal running tolerance $220 firm
a31 hicas pump and lines $100 firm
a31/32 aircon condensor/pump/actuator (some lines included... half are cut so are useless) $80 firm
ssr reverse mesh rims 15x?? with a 0 or neg offset (running 205's with tiny bit of stretch) and 16x?? of the same style running +20 or so offset (id imagine 16x7.5 or 8 +25) full set for 1k very minimal gutter rash if any and no dents - fully balanced - $1000 nego to split into 2 pairs if someone willing to buy the other pair
a31 disc to disc rear end (will bolt into s13/r32/c33) can supply with or without tight viscous lsd - $400 or diff on its own $250 if someone wants to buy cradle for $150
black razo ball shifter - $50 firm
white razo ball shifter - $50 firm
a31 sideskirts (unsure of brand - similar to T's garage or autech - fibergrass) damaged (all in one piece just bashed and needs respray) $100 firm
any queries send pm... will accept near to original price if offer suggested
thanks guys
willing to swap also - looking for 2nd hand good condition z32 afm, ap enginerring rb20det pfc, rb26 crank and rods in good nick, blitz lm or trust air nx pod filter brand new or 2nd hand in very good nick, any ceffy bits mainly a drivers side rear window motor/scissor/mechanism/assembley doohicky
thanks again guys!
  • 3 weeks later...
i have a few items available.
Aftermarket cefiro grill open and meshed - half painted - sold
Perfect condition s1 taillights - $150 neg
JIC 8k springs from Coilovers (just the springs 200mm approx free height and approx 63mm internal diametre- $100 neg
pm me or email me at [email protected]
cheers
resin
Edited by Resin
  • 1 month later...
rar...
A31 drivers side rear door complete with glass - $200 navy blue 1 bit of paint chipped off size of 10c piece
A31 (possible R32) Aircon setup - $120
A31/R32 Powersteering reservoir with lines to pump - $100
RB20DET Injectors x6 pulled from running engine - $160
Greddy 42mm Black boostgauge mechanical - $70
A31 (possible R32) Hicas powersteering pump - $80
A31/S13/R32 Hicas power steering rack - $180
Black Razo 8ball gearknob - $40
Catchcan polished with fittings and oil level reader - $70
A31 RB20DET 4stud hubs/rotors/calipers front and rear - make an offer...
Apexi RSM (oldskool version) - $100
A31 RB20DET Coilpacks in brackets x6 working fine - $100
A31 Late model tailights (tint strip around edges from factory with centre garnish) $230 drivers side has 40mm crack in it... could be fixed with new lense or plastic weld
A31 sideskirts - autech or something... look good - few cracks and poorly painted navy blue - $100 easily repaired
all stuff is in SA... not really willing to send interstate atm - don't have time to
pm's welcome... thanks
  • 4 weeks later...
Hi guys,
For any Cefiro or R32/R33 owners that are interested, we have just posted a new special in the business trader section for our brand new JJR Cooling-Pro Alloy Radiator upgrades.
We are offering them currently for $399 each.
Click the URL below for further details.
http://www.skylinesaustralia.com/forums/in...howtopic=117584
Regards,
Steve
Hi guys,
Regards,
Steve
Cefiro radiator is IDENTICAL to R32 for those who want to know, but it is a good idea to list cefiro as an option cuz most people have no idea :P
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
