just over 130rwkw... nice work
when you say "stock other than a pod filter" what exactly does this mean? to me it means stock exhaust and everything.. but to others, "stock" means including other modifications
if it truly is what i refer to as stock then that's a good (read: high) result for an rb20 with NO mods at all..
do you have a print-out of the dyno graph that you can post up? (don't forget to black-out your numberplate off the top corner)
cheers,
Warren.
yeah I have the printout but no scanner. Will take it to uni next week and copy it.
Also have an aftermarket muffler which probably liberated a few kws.
edit: still running standard boost, stock intercooler etc.
Edited by Big Rizza
  • 1 month later...
I know this thread is old and forgotten, but I bought a scanner the other day and I need an excuse to use it. So here it is, my magnificent dyno printout from a couple of months ago.
Edited by Big Rizza
What did Hyperdrive do Ryan? You only have a pod filter and 177hp is a very impressive figure, just to let ppl know hyperdrive dyno's do NOT read high at all either.
What did this 'tune' involve? Was it basically just a service or what dude?
That sounds pretty impressive for stocks.
I have just got my GTSt,
it has a garret t03 hiflow turbo, 3" dump and a 3" exhaust. Everything else is standard as far as I know.
Any idea what kind of power I should epect at the wheels?
May be a stupid question but I have barly driven it and I'm pretty excited to find out.
No doubt the muffer has helped. :(
My stock GTST dead stock everything made 115rwkw (154rwhp), a little tweak of the afr's (fuel pressure bleed) made 125rwkw (167rwhp). This was on 95ron premium as at the time 98 ron was rare.
A full exhaust it made 140rwkw (187rwhp) but on a different dyno.
A full exhaust 1.5psi extra (up to 12.5psi) and it made 152rwkw (203rwhp) .
FMIC and external bosh pump it made 164rwkw (219rwhp) on 15psi with a fuel pressure bleeder as it was running too rich and killing power.
With 164rwhp it was fairly quick, quite a nice setup to be honest, it would launch 0-100 in around 5.2secs consistently with no wheel spin, which went on to see 175km/h in 13secs.
Start pushing more power and it began loosing traction, with not so consistent 0-100times.
Edited by Cubes
  • 4 weeks later...
Pod style air filter,
Turbo back exhaust.
144kw at the rear wheels
up from 110kw at rear wheels stock.
And to all those that keep saying stock 130kw at wheels are pulling them selves.
Stock means same as factory. not just a pod or just a muffler or just anything. stock s stock modified is modified.
end whinge. :huh:
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
