Time for me to ask a few questions instead of answering a few..
On the weekend, I am taking off my stock turbo and bolting on a Garrett GT30 with a VG30 ass end.
Through all of this process, I am going to change the stock AFM to a Q45 afm. The ECU I am running is a power FC, and its fully tuned for the stock AFM at 210rwkw..
anyway.. If I plug the q45 in, and set the AFM menu in the powerfc to Q45, fair enough things MIGHT work..
but will it change any over all settings or maps etc?
Will it lean the car out or make it run rich? of course, running rich would be a lot better..
The reason is because my fabricator friend and I are going to make everything up for the car (custom) and want to be able to drive the car 30kms to a tuner to do the full tune.. We won't be able to plug in the stock afm in temporarily because its much smaller to fit on the piping.
hope I have made my question clear enough..
thanks in advance guys
https://www.sau.com.au/forums/topic/89274-q45-afm-pfc-tuned-to-stock-afm/
Not an easy question to answer, but I will have a go.
Selecting Q45 on the menu simply loads the Q45 AFM voltage ramp table. This means the Power FC will have some idea of how much air is flowing through the Q45 AFM by its voltage output. It doesn't change anything else, the fuel and ignition maps are still the same as they were.
This usually enables me to start the engine and let it warm up. Then I see what the exhaust looks like with a few quick free revs.
1. If it is belching black smoke I know it is super rich, so I adjust the fuel trim on the PFC until it just blows a little black smoke. Rememer that the fuel trim resets once you turn the engine off. I then know I can safely drive it to the dyno at low rpms using zero boost.
2. If it is clean exhaust (no black smoke) then I know it might be lean. Again I adjust the fuel trim until I can just see some black smoke out the exhaust. Remember that the fuel trim resets once you turn the engine off. I then know I can safely drive it to the dyno at low rpms using zero boost.
Hope that was of some help
:P cheers :)
Edited by Sydneykid
Then you've got the same thing on the ignition side though dont you?
As the q45afm is giving a lower voltage for a certain air flow wont it be looking up a point in the map with more ignition timing than is safe?
ahhh I think I just worked it out based of your explainations
if the stock afm is passing through x (normal) amount of air at 1 volt
the ecu puts in y amount of fuel..
if the Q45 is passing z (more) amount of air through at 1 volt then the ecu still puts through y amount of fuel
in the second equation - more air, same fuel = lean
ouch, I better be careful.
Maybe i could adjust the voltages on the q45 afm setting? Have you noticed when you select q45 on the pfc menu, and hit next again, it has options to change voltages etc..
THis is a little confusing. Hopefully I can get to a tuner asap after the modification
Edited by The Mafia
well, I was just thinking, as even easier way to drive the car around all day every day with this kind of setup, is simply run low boost (5psi or something)
or - no boost at all. Car should be perfectly drivable this way.
Yeah, just picked up my hand controller and tried to change mine over to the setting for RB25 AFM's and you hit next and it goes to the voltage screen. I was hoping you could select the actual AFM and be done with it.
Either way, I've driven mine for hundreds of kays with different AFM's and no problems so far.
It'll drive ok, even with little boost, drove mine like that for 2 weeks before tunes, but it's a different car after tune.
If you"re really worry, get a tow truck, it's $50.00 or about there.
I drove mine around, cause I have nothing better to do.
I installed it but the car runs like puss. You have got to remember that since the AFM is bigger in size, the air flow is now slower.
Hence doing all sorts of weird things to the cars stability.
Need to give it a lot more fuel correction to get it to run stable.
The tuner is going to have fun..
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
