Originally posted by fat313
Do u have any origianal interior carpet?
Yes, not sure of condition or if I can indeed get it ou.. the car's pretty bent...
Do you want the floor carpet or mats?
  • Replies 105
Tony - Sorry sold
Adrian - I can supply everything you'll need except the b/box, which you should be able to source locally easy... PM me with an offer.
  • 4 weeks later...
Dr_Drift, Im after if they are in good condition, the black window trim around the top of both doors and the plastic pillar (the one that people sometimes replace with carbon fibre looking nismo ones) I pulled my sunshades off the windows and the black window trim is all stuffed!
email me: [email protected]
thanks
Dr Drift: Looking at Boot carpet and boot panels. My car is in transit but is supposedly missin the above items.
Pm a price for the lot to adelaide. I cant confirm until i see my car however and it arrives on the 19th of march
Dean
Feryha - I do have the A-Pillar.... what exactly do you need though I'm a bit confused??
Mt Akina - A mountain in Japan that has some awesome twisty roads, made famous by the anime "Initial D"
I'm actually in Melbourne though :)
hey dudes i thought mt akina is ficticous?
anyways have you played that arcade game called battle gear 2 (aka tokyo road race on PS2)
apparently one of the courses is a replica of mt akina from intial d.
and the good thing is that the game focuses on using drift!!
in the arcade it has a handbrake especially for drift!!
Haven't played it...
I believe the name 'Mt Akina' may be ficticous, but the actual anime is closely modelled on actual mountain roads.....
Anyway... getting a bit side tracked...
WRECKING 33 GTSt - All parts gotta go!
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
