  • Replies 105
DR_DRIFT
Did you get my email as i have had no reply.
I am after the ash-tray, how does $10 sound. If not name a reasonable price.
I am from melbourne and can pick it up asap.
Al - Sorry.... demand is a bit higher than $10.... seems a few people want the ashtray?? E-mail me and we can negotiate....
RS72 - Centre Cup / Coin Holder available... currently under offer but no $$ exchanged hands yet... e-mail me to work something out??
Sidewaymambo - Not sure exactly what you mean?? 0411 878 961 if you'd like to clarify...
After steering column shroud - thingo, the two bits (top & bottom) that go between the steering wheel and the dash - My old one had guages on it, and now there are holes in it.
Actually, I just need the top bit...
Cheers,
Boost Junky - I have standard front springs, rear is sold.
Matt31 - SOLD
Brendanf - Collum shroud is perfect, e-mail me an offer.
I will do a complete list of everything in my shed or on the car shortly.
Hey DD i need some parts if you have them.......
Indicator stalk
fuse box cover (the one from the engine bay)
Driveers side rear indicator (the clear lense on the outside under the two red taillights)
Pls let me know either way
thanks.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
