we have a custom paint shop, dyno pack rolling road, full engine build shop ect ect, so keeping the car running wouldn't be a problem to be honest.
So you have the cash, "the paint shop", the dyno, "full engine build shop" etc, yet you have no f**king idea how to build this engine thats not the right one for the job anyway?
I should move over there and set up shop methinks.
EDIT: just saw you went the right engine afterall. well done
Edited by Flipmo
350bhp with responce would be ace.
SR20DET with GT2530, 230-240rwkw (~350hp at engine) with *awesome* response
easy :)
good to see you went the right way and got the sr20 heh.. if your adventurous and have the money, which it seems you do, you can get the TOMEI SR stroker kit and stroke it to 2.4L - then run a GT2835 for even more power with around the same response as the first setup with the GT2530
edit: for more info, head off onto one of the silvia forums, besides ns.com :)
Edited by mokompri
I've decided to do the RB20DET, not RB24 it, going to spend alot less, down to the fact this has to be a car for the company not just for drifting, i still have my other RS13 which is a drift car so it don't matter if this is not as good. Its more the trick factor.
I need a GTR style Plenum? any ideas were i could get something like that?
Yeah go a s15 front cut conversion like JMS in australia have done.
The SR's are proven too produce the goods and they are still within the weight/handeling capabilities of the cars supension systems.
A full blown sr will munch the RB at drift duties.It has a better flowing head,alloy block! Put quite simply it is a modern engine where as,sorry to say this guys,an RB20 is vitually a dinosour.
If you had an R32 then it would be a different story id say.Then you would start looking at Rb25's/26's.
You will want a light nimble car with loads of on tap power to burn on call mid way through a corner.
What sort of gearbox have you chosen for the car.Custom ratios all the way baby.
As i say the engine has been moved back into the bulk head so it should be very good. As for suspention i'm running on Coil overs so spring rates are interchangable.
Its goign to be built up with TD06 20G now anyways, started ordering th parts yesterday.
THE thing i need the most, is a custom intake plenum? does anyone know were i can get one from, i have money waiting!
unique autosports in sydney <--click here.
          OR
subzero in brisbane.
Please tell me i'm wrong on this, but looking at there RB20/RB25 half plenum (no runners)
Don't the RB20DET runners have the back two out of line??? so this wouldn't fit. do RB20 and RB25 stuff fit the same to the head?
I mean do i have to buy this then find a RB25 runners?
Edited by superclarkey
let me start by saying nice choice, i am a bit of a fan of the rb24 and will be building one in the near future, BUT like sydney kid stated i think your goals are a little off for starters are you after 500bhp or 500rwhp (as you stated 500bhp at the hubs?) as there is a big difference and i think both are a little high for what you NEED to go drifting (drifting isn't ruled by hp) i think a figure more like 400 to 450bhp or 340 to 380rwhp would serve you well and should be able to be gain with decent responce. The first turbo that comes to mind is the GT3071R as featured on the ATP web site on a 2.4 litre motor making 400bhp and full boost by 3000rpm
http://www.atpturbo.com/root/releases/release051404.htm
with the motor your building you might even get away with the GT3076R
As for the motor configuration i know your got the money to throw at it but it really doesn't need alot of big dollar engine parts to do what you want reliable.
New R34GTR Crank $1100 aud (good to 10,000rpm and seen 900bhp+)
New N1 oil pump $560 aud
GTR rods with new arp rod bolts (again seen run 800bhp+)
Tomei forged rb24 piston
Tomei gasket kit
Nismo main bearing
Nismo big end bearing
Solid lifter kit
Cams 260deg 10.25mm and adj cam wheels
600cc injectors
Nismo fuel pump for gtr
APEXI pfc and avcr
Z32 afm
gtr intercooler (i would not go big as its not need and would only hinder responce)
Greddy 48mm radiator
oil cooler with relocator(brand etc doesnt really matter)
you'll need to do some nice custom work aswell
exhaust
plenum
head porting
obviously you can buy nicer name brand gear but i just stated what i think you need to achieve your goals and the let over money might be wiser to be invested in suspension, diff, gearbox, brakes, cage etc the gear you really need to be a good drift car.
my2c
pete
Lol, Its a case i know what i want to do with the engine, but i've got to convince the person thats funding me to also want to do it. I'm defo doing RB20DET at the moment, i picked up the crank yesterday from Abbey, New GTR34 Crank paid for out of my own pocket, because of the time scale to get this car ready for its car show at the NEC birmingham in Jan, something must be kept simple.
pnblight thats a nice spec and something i was very much looking at. I wanted a GT3071R turbo from ARP but i can't afford it under budget at the moment, so Greddy TD06-20G is were its at.
unique autosports in sydney (just contacted them they do not sell plenum for the RB20DET, RB25 only)
OR
subzero in brisbane. : can someone help me find a contact please for subzero as i can't find a website for them.
The plenum is the most import item at the moment, the engine will not fit without it, so please help me track one down.
MAny thanx
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
