ey lads just wondering if i can round up a few names for custom cefiro billet steel boss kits,
at the moment, only HICAS systems are availiable, however a lot of cefiros were born with HICAS, if interest increases, i can organise a non hicas model aswell.
These items are being custom made, for cefiros, not s13s. not skylines, not anything, just cefiros,
meaning they will sit perfectly flush against your steering column, and will be super high grade alloy material, in other words, they will look the balls...
a proper quote will be organized once i have a roundabout number of people interested, but be prepared to pay around the 100 - 120 mark,
it's more expensive than the plastic HKB boss kit i know, butt the HKB is non hicas, and you will lose the function of auto cancelling indicators,
once again, these boss kits will be the balls, so feel free to ask any questions etc you may have regarding making this group buy a possibilty, get it? possi-BILLET-y? HAHAHA god i need to get a life
cheers guys
https://www.sau.com.au/forums/topic/89329-eoi-billet-steel-boss-kits/
will get one probably tonight or tommrow, but they are alloy boss kits, no bumps no lines, just smooth as steel shiny bosskits specially made for ceffies with hicas (possibly no hicas)
have you got a momo wheel? a31rb25
at the moment i've got a wheel that's the same hole pattern as a mom, but am gonna get a quick release hub and Nardi wheel.
any idea on overall length - wanna make sure i can still reach the indicator with a quick release kit
the length will probably be posted up as soon as i get mine built, aaaand seeing as mine will be done on wednesday, i may as well wait until then to take pictures rather than get pics of my brother's 180,
if multifit is easy to do, then i will organize a multi fit but at the moment, due to the popularity of nardi patterns, it might end up being a nardi only... but as i say, it can sway either way as it's early days...
hope you're all having as good of a weekend as me!
whats different about these that make em compatible with hicas ....i bought one at auto one a while back .....and i tried out a few ..r32, s13 etc ...and none would fit untill i got this european made one ...and it fit the spline fine and ..indicators work etc .....
cetain bolt holes are placed in different places to the non hicas version, same as s13 non hicas boss kit will not fit a hicas s13,
they fit, but a few of the guys on d1nz forums claim you can lose your indicators auto cancel function, and the horn doesn't work...
plus this is billet steel. it looks cooler!
    • Even with no BOV you will have issues unless the MAF is a hot film type like the R35 which has some design features to deal with reversion. Hot wire MAFs are very sensitive.
    • So i just change the (whatever is inside ma original MAF and slide the R34 MAF (it is gonna fit right in? ) and somewhere on the hot side a BoV...i presume that would be vented to the atmo? I just "trying" to understand...maybe my mechanic would know this   I would not mind(even prefer) to run stock BoV cuz it is way more than fine but i do not have that and only pipeing what is left is oem J pipe ... I will be running Blitz fmic(to fit oem one side style) and i gonna need custom pipes cuz i do not have rest of those pipes and hoses... But i am want standalone ECU. Only choice i have atm is Nistune...but that is not gonna cut it right?I dont know what Nistune can and cant do... I know you guys know Link and Haltech...but whatabout ECUmaster? I know guys in here run those but i literally do not know about that and do not know differences... Just know to take whatever "my" tuner can work on.
    • Is that the blue one rpm?
    • Update 2: Today I'm f**king pissed. Some of you probably saw my thread that I opened shortly after joining this forum, "urgently need expert/experienced opinion", in which I discussed the possibility of a porous RB26 engine block which I also found hard to believe. Currently both turbos are out since the shitty braided line that was installed by whoever fitted the GT28 turbos leaked oil onto the exhaust. Today while working on the cam covers to put new gaskets and half moons in, I cleaned the side of the engine block with brake cleaner. Some time later I saw that it was still glistening with oil or coolant so I dried that off. But it was wet again shortly after. Verdict: I'm royally screwed. What you can see here (hopefully, despite shit resolution), circled in red, is a crack above the turbo oil feed. Extent is a few cm long and basically goes from #3 cylinder wall to #4 cylinder wall. It slowly lets coolant through, even without any pressure behind it. I am absolutely dumbfounded as to how this crack even formed, especially since it isn't along the cylinder as it usually is but rather a horizontal crack. Probably a few cm in length. Not sure on how to deal with this issue right now. Most likely, the only true fix is a new engine block, and even a relatively well done temporary fix requires at least a full engine teardown. Neither of those really fit my timetable right now, the car has been in my buddy's garage long enough as it is. I'm open to suggestions, but I'll be looking into ordering a new 05U block soon so I have one ready for the coming year, or whenever the current block inevitably fails fully. (Most likely once the crack reaches one of the frost plugs) I think it'd be a waste of money and time to rebuild the engine with this block. Oh and I found a rust hole on the side pocket of the trunk, which someone covered up with sealant goop, a piece of number plate and bodywork filler. Fun times. So far for every issue we fix we just find a new one that is arguably worse.
    • I have not found this no. I put one back on a couple days ago with no drama. I agree they are tight, but no need to remove anything.
