"3 your fuel pump is not dying? it happened to me and it confuses the ecu showing a/f is good but it's actually constantly retarding timing and i only reached no more than 150rwkw till i replaced the fuel pump. "
This strikes me as possible.
i assume i attach a t piece with a pressure guage to test the fuel pump. I'm getting good economy and it doesnt miss at all when i floor it.
  • Replies 46
Posted Images
What plugs are you running?
The top end looks as if its flattening out a little, that could be due to the plugs, it could also be due to a restriction in the exhaust or as some one else mentioned wheel spin on the dyno.
If power had not have flattened out it would be up around 148rwkw.
I do agree though, that power figure is embarrasing. :)
150rwkw doesn't feel fast anyway, its only once you are up around 200rwkw it starts feeling fast.
My 176rwkw felt slow even though it was making 100 of those rwkw by ~2000rpm. This was run in 4th but only taken to ~6000rpm due to it not making any more power after 5000rpm. Torque dip in the middle is wheel spin.
Edited by Cubes
wow great result there. does the full exhaust include dump pipe?
Yeah its got a dumper, but i believe the muffler is very restrictive (its not even a straight thru). I'm running coppers that mercury gapped down to help my ailing coilpacks, which are on the way out :)
You guys believe dyno figures too much.
Example... my stock R33 GTS-T with a cat back exhaust and aftermarket fuel pump was dyno'd within a week at two places.
Unique Auto Sports = 156.1rwkw
Castle Hill Exhausts = 140.2rwkw
Nothing on the car had changed and same batch of fuel.
Goto agree with Tommo, main reason why you should always get your car dyno'd at the same place, providing they don't change their setup, you atleast will have figures relavant to previous ones that are accurate..
although - goto say <140 sounds quite low..
Guys i seem to have miraculously fixed this problem.
By the push in the back im guessing ive just gained an extra 30-40kw!
It was a leak on one of the smaller hoses going to the inlet manifold causing the disturbing whistle at high rpm, and also must have been sapping the power.
i will still get it dynoed, but the car is running smoooth as, and fast!
I'll keep youse up to date.
Great stuff mate, very good to hear it was a simple fix.
I'm suprised the guys dyno'ing it didn't notice :P
That said though, I didn't even think that was a incorrect figure, rather a slightly out dyno... but you've proved me wrong :D
Edited by TommO
Guys Guys Guys
I have read so much in the forum about Power figures I think it is quite strange that noone has done there homework on this
A stock GTS-t R33 makes 180-185kw at the flywheel which equates to a LOT less at the wheels.
A stock car will make approxx 120-130 HP at the wheels which is 88-95kw at the wheels. This I know because i have seen my car which was completly stock when i bought it and in fantasic condition and i have gone down the road of modifacation.
My car has now produced 210 HP at the wheels which equates to 154kw which is starting to become a nice street car I have a Hiflow Turbo coming and a SAFC tune on the way. I completly fail to see how the figures that you guys are talking 200rwkw with a stock dump pipe I cant help but feel that this is a crock of shit 200kw equates to 271hp
Which u JUST CANT GET with a stock dump PIPE I had to go for a aftermarket dump pipe when i hit 185-190 hp at the wheels. I think someone is telling porky's
I will probably get flamed for this.
Guys if you think i'm talking crap Google the standard power figures and make your conclusion.
http://www.digitaldutch.com/unitconverter/
Drivetrain loss is roughly 30% I thought. Ie stock R33 gts-t with 185kw at the fly will be roughly 130rwkw. R32 gts-t with 160 will be 110. Works for me. I think everyone in this thread was talking kilowatts weren't they?
So what your saying is a stock R33 GTST looses around 90kw going to the back wheels?
Once again, dyno's differ, especially different brands.
My R32 GTST making 160fwkw dead stock made 110rwkw.
Exhaust, fmic and boost it jumped to 164rwkw. I had the car on 3 different but same brand dyno's. One varied -10rwkw, it was on a 35degree day though.
85-90rwkw for 185fwkw is unrealistic. My old N/A VLmade 80rwkw on an old school dyno that had a big clock and needle looking thing that gave the power readout. :)
whoever sold you the dump pipe is laughing right now... did you dyno the car with the exhaust dropped to make sure there was a restriction?
more importantly do you already have some kind of fuel management because the standard ecus tendency to richen the top end mixtures when boosted will rob you of alot more power than the stock dump pipe...
In fact with your 'highflow that is coming' you may want a ecu that lets you adjust the ignition timing not to mention that you will probably want to use a/m injectors too... unless your going to run a highflow with an SAFC and standard injectors but your not afraid of frying the rings are you!
Finally just cos your car was in great condition on the outside doesn't mean that the motor has perfect compression ...remember your talking about a 10yr old turbo car here... and don't even start me on believing the odometer reading!
so yeah the stock dump pipe isn't a huge restriction and can happily stay as long as the stock turbo, other things are more important imho
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
