"3 your fuel pump is not dying? it happened to me and it confuses the ecu showing a/f is good but it's actually constantly retarding timing and i only reached no more than 150rwkw till i replaced the fuel pump. "
This strikes me as possible.
i assume i attach a t piece with a pressure guage to test the fuel pump. I'm getting good economy and it doesnt miss at all when i floor it.
  • Replies 46
Posted Images
What plugs are you running?
The top end looks as if its flattening out a little, that could be due to the plugs, it could also be due to a restriction in the exhaust or as some one else mentioned wheel spin on the dyno.
If power had not have flattened out it would be up around 148rwkw.
I do agree though, that power figure is embarrasing. :)
150rwkw doesn't feel fast anyway, its only once you are up around 200rwkw it starts feeling fast.
My 176rwkw felt slow even though it was making 100 of those rwkw by ~2000rpm. This was run in 4th but only taken to ~6000rpm due to it not making any more power after 5000rpm. Torque dip in the middle is wheel spin.
Edited by Cubes
wow great result there. does the full exhaust include dump pipe?
Yeah its got a dumper, but i believe the muffler is very restrictive (its not even a straight thru). I'm running coppers that mercury gapped down to help my ailing coilpacks, which are on the way out :)
You guys believe dyno figures too much.
Example... my stock R33 GTS-T with a cat back exhaust and aftermarket fuel pump was dyno'd within a week at two places.
Unique Auto Sports = 156.1rwkw
Castle Hill Exhausts = 140.2rwkw
Nothing on the car had changed and same batch of fuel.
Goto agree with Tommo, main reason why you should always get your car dyno'd at the same place, providing they don't change their setup, you atleast will have figures relavant to previous ones that are accurate..
although - goto say <140 sounds quite low..
Guys i seem to have miraculously fixed this problem.
By the push in the back im guessing ive just gained an extra 30-40kw!
It was a leak on one of the smaller hoses going to the inlet manifold causing the disturbing whistle at high rpm, and also must have been sapping the power.
i will still get it dynoed, but the car is running smoooth as, and fast!
I'll keep youse up to date.
Great stuff mate, very good to hear it was a simple fix.
I'm suprised the guys dyno'ing it didn't notice :P
That said though, I didn't even think that was a incorrect figure, rather a slightly out dyno... but you've proved me wrong :D
Edited by TommO
Guys Guys Guys
I have read so much in the forum about Power figures I think it is quite strange that noone has done there homework on this
A stock GTS-t R33 makes 180-185kw at the flywheel which equates to a LOT less at the wheels.
A stock car will make approxx 120-130 HP at the wheels which is 88-95kw at the wheels. This I know because i have seen my car which was completly stock when i bought it and in fantasic condition and i have gone down the road of modifacation.
My car has now produced 210 HP at the wheels which equates to 154kw which is starting to become a nice street car I have a Hiflow Turbo coming and a SAFC tune on the way. I completly fail to see how the figures that you guys are talking 200rwkw with a stock dump pipe I cant help but feel that this is a crock of shit 200kw equates to 271hp
Which u JUST CANT GET with a stock dump PIPE I had to go for a aftermarket dump pipe when i hit 185-190 hp at the wheels. I think someone is telling porky's
I will probably get flamed for this.
Guys if you think i'm talking crap Google the standard power figures and make your conclusion.
http://www.digitaldutch.com/unitconverter/
Drivetrain loss is roughly 30% I thought. Ie stock R33 gts-t with 185kw at the fly will be roughly 130rwkw. R32 gts-t with 160 will be 110. Works for me. I think everyone in this thread was talking kilowatts weren't they?
So what your saying is a stock R33 GTST looses around 90kw going to the back wheels?
Once again, dyno's differ, especially different brands.
My R32 GTST making 160fwkw dead stock made 110rwkw.
Exhaust, fmic and boost it jumped to 164rwkw. I had the car on 3 different but same brand dyno's. One varied -10rwkw, it was on a 35degree day though.
85-90rwkw for 185fwkw is unrealistic. My old N/A VLmade 80rwkw on an old school dyno that had a big clock and needle looking thing that gave the power readout. :)
whoever sold you the dump pipe is laughing right now... did you dyno the car with the exhaust dropped to make sure there was a restriction?
more importantly do you already have some kind of fuel management because the standard ecus tendency to richen the top end mixtures when boosted will rob you of alot more power than the stock dump pipe...
In fact with your 'highflow that is coming' you may want a ecu that lets you adjust the ignition timing not to mention that you will probably want to use a/m injectors too... unless your going to run a highflow with an SAFC and standard injectors but your not afraid of frying the rings are you!
Finally just cos your car was in great condition on the outside doesn't mean that the motor has perfect compression ...remember your talking about a 10yr old turbo car here... and don't even start me on believing the odometer reading!
so yeah the stock dump pipe isn't a huge restriction and can happily stay as long as the stock turbo, other things are more important imho
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
    • Yes shipping here can be a pain, was about to purchase timing belt replacement kit, but it tends to get expensive due to shipping (and customs if importing from non-EU which the UK now falls under).
