  • Replies 42
Ken is talking about his driveway, he want us all to go around an drift around his place.
Joking aside, it is high time that Perth had a much improved race circuit with drfit circuit and go-kart tracks. I apreciate that the WA Sporting Car Club deon't have sufficient funds to improve Barbagello to the standard required, we can barely hold onto the V8 Supercars, as we have one of the worst cicuits in the country.
The motorplex is an excellent venue, and a race circuit of this nature would be a very good idea. Motorsport is huge in WA and Australia, why doesn't the government provide some financial support for these sports?
I hope you are right Ken, and that we might have an appropriate venue soon.
See'ya:burnout:
Its not the standard of Barbagello fault that we are close to lusing the v8 supercars, there isnt anything wrong with barbagello. its just miles from the city and a city that is miles from anywhere else, what else could we get in perth? We have the wrc which is huge, a dedicated drift circuit? thats a bit wishful thinking, c-red and mc motorsport seem to do ok at barbagello. Drift is barely even a sport. Kinda like syncronised swimming
Originally posted by skyzerr33
just wait and see who gets to redevelop the land next to the airport. someone has put in a proposal to turn it into a race track.
If you are talking about the proposed F1 circuit from that tosser Roberts then don't hold your breath.
This is the same flogstick who put the SAME proposal up at the old Military Market site in Midland AND the SAME proposal up to the council at the end of Nicholson Rd way.
The guy hasn't get 20c to scratch his arse with and he expects someone to cough up around $40 mil to build it.
What a wanker.:whackit:
As you can see I'm less than impressed with this idiot as he does nothing but alienate the general public against motorsport with his false promises.
Ken
C Red did a good job at Barbagallo but now have big problems arranging insurance thru CAMS ( ie. they don't want to know about drift ) which means that the WASCC won't lease it to Jeff for drift , er , training days.
That , and the hire fee is ridiculous which Jeff has to pass on to the entrants which then makes it too expensive.
Cheers
Ken
See'ya:burnout:
Not a chance phptf , I just got the paving relayed !
Seriously , there is gonna be a good venue announced shortly which will have some large open bitumen linked with some tightish , perfect for drift style corners .
It is NOT a burnout pad ( go to the plex for that ) and these people have the ability to cover there own insurance.
As I said , watch this space.
Oh , and btw , it will be within 20 mins of the cbd.
Cheers
Ken
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
