Hey all,
i know i was looking to buy a ceffy but with all the trouble i had with buyers coming around talking shit, and not having any money i have decided to swap with a mate. The new car is turbo, the new car is HOT, the new car is P.I.M.P.
Some people do not like them and some people do, me personally when i first saw it at my mates place i fell in love, the guy who im swapping it with is actually on these forums.
it needs a couple of touch ups on the body but apart from that its pretty straight.
without further fart assing around here it is.
Y31 Nissan Cima.
full INSURANCE bodykit
dished rims
yakooza boot space.
it has it all. the perfect cruiser.
https://www.sau.com.au/forums/topic/89374-heres-my-4-door/
Pimpin!
are you a sydney sider? I have the car in my sig. a Y31 gloria and i too love teh pimpmobiles...
what sort of engine is in it VG30det? You dont happen to have a pair of front struts spare do you :)
or know somewhere i can get a set?
If you are in sydney i would love to come and have a look at it as i have always loved the cimas. I want to organise a cruise for Cimas, cedrics and glorias. :P
Cheers mate
https://www.sau.com.au/forums/topic/89374-heres-my-4-door/#findComment-1613392
lol gaf's old car being put to proper pimp use now :P
I swear that badge/impaling shaft has got me so many times now.
In for 4 door SAU VIC meet. You biznitches should have come to the one on the weekend.
https://www.sau.com.au/forums/topic/89374-heres-my-4-door/#findComment-1624196
JAPWTGAT (japs with gats)
SCR8PCTY
BMPACRAKA
VIEYEPEE
CIMA2NV
URRBAGS
DRVBYBNDT (drive by bandit)
2LOW4JAK
how about
PMPN:NTEZ (pimpin ain't easy)
SHTUPHOE
BUSTACAP
BABYPWDA
PASHABTCH
YOUSAHOE
JMPINBICH (jump in, bitch!)
FKUPAYME (i want that, f**k you, pay me!)
ENJYRSLF (Enjoy yourself, bitch!)
i wanna get "I H8 U"
https://www.sau.com.au/forums/topic/89374-heres-my-4-door/#findComment-1626080
CIMAKA ... "see my car" :D its an old one gaffa came up with I think, which I found pretty amusing.
I'm guessing you're in VIC, so you're restricted to 6 letters. VIPJNR was another one I suggested to gaf (as it was the smallest of the VIP cars at J-Spec).
CIMANUTS is the one you'd want though, shame it dosen't fit.
https://www.sau.com.au/forums/topic/89374-heres-my-4-door/#findComment-1626107
CIMAKA ... "see my car" :P its an old one gaffa came up with I think, which I found pretty amusing.
CMANUZ - will fit :)
i was going to get DRF-PIG for my 32... but thought its probably best not to stick a custom plate on as theyre too easy to remember.
https://www.sau.com.au/forums/topic/89374-heres-my-4-door/#findComment-1626928
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
