hey it happend again tonight!
comeing off an exit onto another highway, i gave it some juice and as i hit the straight the car started loseing power.. then back on.. then back off.. ect! it feels like when u have no fuel left in your tank! bt it was half full!!
could this be a fuel pump issue? fuel filter? also is i bad for the car to be doing this?? will it damaged it?
thanks rhett
could also be an electrical bug too.
mate of mine had a pinging problem yesterday. "usually" fuel related, right? it was actually the knock sensor wire exposed and rubbing on the firewall.
am just saying, dont rule out anything yet........ try all the little things first, and rule them out one by one. (eg. fuel filter etc...)
i dont think it would be fuel filter because its only happening randomly. the car will run fine then when it startes putering.. u put your foot down more and it will keep going untill u take your fooot off n wait like 10 seconds?
Hi champ,
could be your fuel pump or air flow meter.
does it hunt sometimes while ideling. if so take out the air flow meter and give it a clean with carby cleaner. dont touch the wires just give em a good spray.
then reset the ECU by disconnecting the posative terminal on the battery while a mate keeps his foot on the brake. do this for 3 min and then reconnect the terminal and the ECU will be reset.
If thats not the problem it may be your fuel pump is on its way out. is it ever noisy?
no not realy? i have already rest the ECU 2 days ago. can u use degreeser? and spray down the air flow meter?
no not wile ideling.. it wfeels like when u have no fuel left but u give it to here anyway and it chugs.
don't use degreaser to clean an afm, carby cleaner or brake cleaner
it sounds like the problem is your air-flow meter. are you using a HKS powerflow style pod filter with an oiled foam element?
What happens, is the oil from the pod filter, hits the airflow meter sensor and screws it up, you can't really fix this by cleaning it, when it happened to my car, i needed to replace AFMs (r33 and r32 gts-t afms are the same btw)
so your 32 was doing the same thing?? i do have a pod filter i dont know if its oiled or not... a little to late i just cleaned it.. eeep.. i took it for a test run its working fine though??
well i cleaned the AFM so ill go for a little drive n see if it does it again.. if it does ill do the fuel filter
yeah, my 32 was doing the same thing
http://www.skylinesaustralia.com/forums/in...showtopic=74808
i just dug this up, here is my description of the problem
Someone suggested I change afm's and it solved the problem completely.
I tried cleaning it first, and this didn't fix it, I had to completely replace
hi there, i am having the same problem, and am also trying to diagnose it.
Ok, from time to time, just driving normally, it'll "hesitate" and u litterally loose all power for a split second, then it comes back on. It does this from time to time
when it's bad. it'll do it alot. (like on-off-on-off bucking you describe). and eventually u usually have to pull over.
When i pull over. revs will idle funny - like 1k - 2k - 1k - 2k - 1k - 2k back and forth for a while, and will then either settle down, or the car will stall. Although idle is jumping between 1 and 2k, it's still smooth, when you're standing still, it's not eratic. (does it do this on your car?)
Because it's idling like this, i'm wondering if it might be a Idle-control valve problem, or coolant temp sensor. The other thing i'm getting is an unusually high cold-idle in the morning - this could be unrelated however. I haven't checked for ECU fault codes, but i'll do this tomorrow morning.
I've tried removing the bov and blocking intake off with a plate, and blocking vac-line off, but makes no difference.
-Tim
If you have a friend with an r32, try swapping airflow meters
about 3 or 4 people posted later in that thread saying that they had the same problem and afm fixed it.
Edited by MerlinTheHapyPig
yeah the AFM cleaning didnt work i need a new 1! it was playing up realy bad yesterday i nerly didnt make it up my hill... i noticed that if u pull over and let it idel for 10 seconds it will go back to normal for a wile... u guys niticed the same thing?
any 1 know where i could get a new AFM?
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
