Hey guys...
Doing my top mount gt3540 setup and have decided to go with bigger injectors now seeing that I have got my manifold off as well...
Anyway the question i have is that I want to get injectors that bolt in with the least amount of fuss and i hear that the Nismo 740cc injectors high imp side feed are the go - but do they bolt into the rail and do the wire plugs plug in also ? do you need anything else to get these injectors to work as I know you need collars for the sard injector series what do you need for the nismo ones?
Anyone installed these before in a r33 gtst s1 and know whats involved ? I am ordering them from Nengun.
What rwkw are these good for ? would they do 320 rwkw without a prob?
Thanks
I ordered on tuesday and he confirmed the order 10 minutes later, confimed the reciept of payment the next day and gave me the 8th of october as the expected delivery date.
2 week turn around from date of order is not bad at all.
Yes we are running a set of Nismo 740cc direct replacement in a R33 GTS-T and its currently pushing 320rwkw, (430hp) at 20psi with only about 65 - 70% injector duty, so they will easily handle more. The only thing you will need for the injectors are new o-rings which are fairly easy to get from any auto shop.
Edited by BBQ
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
