no support for air-temp on ecr33 powerfc, the hand controller shows it but the powerfc doesnt support it, where the airtemp hooks up on the rb26 powerfc the er34 powerfc has an empty wire pin but the ecr33 has a wire which is something else so it wont work
https://www.sau.com.au/forums/topic/89430-air-temp-on-pfc/#findComment-1614344
Can we adapt one though ?  im sure we can somehow!!!  does the computer support it?  can we adapt a sensor and wire it into the PFC ?
This will be a great mod IMHO
I have used inlet air temp connection on an R32GTST Power FC by connecting up an R32GTR sensor, good chance it would also work on an R33GTST. The RB25DET Power FC has an air temp correction table that can be accessed with Datalogit (and I assume Apexi Excel), however it isn't accessible with the Commander on the models I have seen. So the PFC software would appear to be able to support an inlet air temp sensor, otherwise it wouldn't have a correction table.
The intake air temp sensor is pin 36 on the R33GTR, so the first thing I would do is check and see if that pin is used on the R33GTST ECU plug. If it isn't used, then connect up an R32/33GTR inlet air temp sensor and see if it is recognised.
:) cheers :P
https://www.sau.com.au/forums/topic/89430-air-temp-on-pfc/#findComment-1614817
  • 3 weeks later...
the powerfc is burnt (smells bigtime bad) and the stock ecu does its normal thing but doesnt complete the start sequence somehow (no idea why).
i unplugged the water temp sensor and tried tapping it onto some of the empty spots on the ecu, after i tried a few i tried one more and then it died, i must have shorted two of the terminals together
my own fault
https://www.sau.com.au/forums/topic/89430-air-temp-on-pfc/#findComment-1658519
crikey, i would be so p****ed with myself if i did that.
unfortuanetly i am going to say i would be suprised if this powerfc ever goes again, not all the circuits are protected that well in them.
being all surface mount as well will make it a prick to try and repair.
have you opened it, can you see the burnt out components at all?
man you must be spewing so hard? (unless your rich c**t i guess)
https://www.sau.com.au/forums/topic/89430-air-temp-on-pfc/#findComment-1658529
yeah im a bit pissed but tis my own fault for fiddling, no one else to blame
nah im not gonna open it, ive got a contact who can come and look at my car and sort out the starting issues, he can also repair the powerfc.
again it depends on what ive cooked inside it, could be one component or could be the whole board. if i have to buy a new one so be it, just learnt the hard way
https://www.sau.com.au/forums/topic/89430-air-temp-on-pfc/#findComment-1658545
yeah its all good, just wanna get it fixed and then move on
hopefully ecu can be fixed too, no doubt its cooked to all buggery though
oh well the price to pay in the aid of experiementing and learning stuff :D
https://www.sau.com.au/forums/topic/89430-air-temp-on-pfc/#findComment-1658572
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
