ohh ok, was under the impression you got it back from him, hence the pics.
anyway, now that you have it apart is there any burnt/black carbon tracks on the board, sometimes you get lucky and even if the circuit isn't protected the tracks just get hot, lift from the pcb and burn into two pieces, that can be easily joined again with small guage wire?
nah i looked and cant see any burnt stuff, it all smells the same, i checked undernearth and its still perfect, looks brand new still. so not sure whats dead. maybe nothing is dead and ive fried something on the car instead and the powerfc just has a fit cos something on the car is angry. hard to tell. id say ive cooked something though cos it smells burnt
post mortem diag, found a burnt track on the powerfc board and stock ecu still doesnt start the car. did stock ecu diag with consult no errors found. just cant for the life of me think why it doesnt crank over
powerfc has been repaired. resoldered burnt track. car runs fine, system appers ok and tune still present. go the ol mighty rb and powerfc :blink:
pelase do not attempt the manual air temp sensor hookup
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
