Hey all just got a black r34gtt 38000kms, complied last month :cheers:
ill post some pics sometime soon :)
I live in syd and am looking for a good place to do a custom 3 inch full exhaust maybe.
also it came with a non standard BOV, just wondering where i can get a factory BOV as i dont want a defection :S
tnx for any help
Edited by Shado34
https://www.sau.com.au/forums/topic/89447-new-car/
tnx all for the help, ye its a HKS SSQV Blowoff Valve Kit i think.
Trying to geta digital cam, will try poat some pics soon :)
Welcome to another 34GTT owner :)  Damn our private community is growing larger and larger everyday - saw three 34s in the city last night not including mine :(  Was it you?
no wasnt me i havnt done a city run yet :)
Edited by Shado34
https://www.sau.com.au/forums/topic/89447-new-car/#findComment-1615126
yep thats pretty much defectable.. as many car mods are..
If u let it off whist police are close, and the police know what it is. (though they usually call hwy cars to come and look at the car).
Get a stock one quick! :)
Have you tried HiTech Mufllers? I think they are good. Though dont know and never been there.
https://www.sau.com.au/forums/topic/89447-new-car/#findComment-1615131
hey all, i was wondering if its normal for the boost guage to be at -0.5 to -0.6 when idle (i know it should be a negative figure at idle but this low?), it goes up to the lo boost and hi boost fine when im driving but this just worries me abit ;)
Edited by Shado34
https://www.sau.com.au/forums/topic/89447-new-car/#findComment-1616124
yea dont worry about it.. The stock gauge is always usulaly very wrong.. bet a aftermarket one its better.. and it has zing factor :D
i havent seen one thats wrong, have you?
the only thing i notice is that they are slow to react (electric) and the markings dont give enough detail.
https://www.sau.com.au/forums/topic/89447-new-car/#findComment-1630712
Man, you've got a sunroof....
couldn't find one with a sunroof, unless it was auto...
btw nice car, have you got any plans for it?
nah mine dosnt have a sun roof, i had a look at one with a sunroof but it effects head room...
I plan on getting power fc first and soon turbo back exhaust; then i might work on a sound quality audio system :)
https://www.sau.com.au/forums/topic/89447-new-car/#findComment-1661249
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
