My gearbox is fine now that i have redline right through.
BUT now there is ( what the redline rep calls ) diff chatter. a clunking sound like the cogs arent quite reaching when crawling slowly in first or reverse with the steering turned.
Has anyone an explanation to this or similar problems as it is very noticable in my GTR?
  • 3 weeks later...
im just wondering guys , is there a difference in buying the lightweight
and superlightweight for the gearbox??
I need to get some of this stuff soon for R33 GTR gearbox and would like to know whether to get the light or superlight also.
Anyone recommend which situation needs which oil?
Can you use Redline oil for the transfer case also?
