  • Replies 40
Posted Images
  • 3 weeks later...
ah ok, yeah definitly landed
just had the compliance plate applied for like tuesday this week, should by complied by late next week, then having some work done on the car, so shouldn;t be too much longer till i get her!!
They sent off the letter for compliance plate before it was actually complied?
nice rims btw, not sure if I want white or black ones on mine :)
Cars not complied until the plate is stuck on her!!! I guess what i meant is that the workshop had approved to have the paperwork submitted and have the plate applied for!
Dezz im in Adelaide but the 34 is being imported through a WA based group, so all of the compliance work is going to be completed over there, then sent over here VIA train to be registered in SA. Compliance has taken quite some time for mine as it had a reasonable amount of modifications, and there has been some difficulty in securing stock parts to allow the car to pass compliance. Its been a long wait for me, but hopefully the wait will be over soon! I'm sure it'll all be worth it once i've got the 34!!!!!!
I'm not a big fan of TE37's myself, so im contemplating selling the rims, only if i can find another pair im interested in though.
They will comply the car before the letter for the compliance plate is sent.
Dezz: Currently there has been some hiccups in the customs department if you have read the news. It's about some new system that screwed up. Things being imported into the country will be processed slower than usual and that includes cars.
Journey from japan is going to take about 2 weeks or more, so you can count down from that.
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
