new owner of a 32 gtr, in panel n paint shp atm, jus some questions about the setup
-is it a sequential type system?
-is it 1 manifold with 2 turbos on it or 2 manifolds, 1 for each, each running on 3 cylinders
-getting aftermarket gear, are 2 wastegates needed? im guessin ye because of the 2 turbos...
-ive seen a few ads for parts and it shows 2 seperate manifolds?
-a common question.... single turbo VS twin turbo?
any other information about how the engine works would be greatly appreciated. im familiar with my old SR not thi engine :)
novak
https://www.sau.com.au/forums/topic/89463-new-to-rb26dett/
novak
sequential
>> -is it 1 manifold with 2 turbos on it or 2 manifolds, 1 for each, each running on 3 >> cylinders
2 manifolds, 1 for each, 3 cylinders
>> -getting aftermarket gear, are 2 wastegates needed? im guessin ye because of >> the 2 turbos...
the stockers have internal wastegates with actuators attached. you can goto bigger twins and they will come with upgraded internal wastegate and actuators. you would only need twin external gates for a large twin setup, like gt2835 or larger in pairs
yes its basically two 3 cyclinder manifolds, v shaped. 1 turbo per manifold
depends on budget, power goal, wha u want to do with the car and if you care about defects, looks in engine bay, use of air intake etc. do a search there was a massive single vs twin on the rb26 thread about 5 months ago
https://www.sau.com.au/forums/topic/89463-new-to-rb26dett/#findComment-1614639
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
