Munched my First Clubsport
  • Replies 55
nuthn beats seeing the face of a new monaro 255 owner gettn chewed by a pretty stock r32 gts-t. been there, done that, and just to think.....theyve spent 70 odd grand on that cheaply build aussie shit car. and a note to all you bogans out there, PUSHRODS ARE DEAD!!
I agree with akeenan, if you are in front you have the right to end it! I always stop 10 to 20kms over da speedlimit. But yeah, it's so true how they always speed off into the distance! I always hit hazards if I win, but I might switch to indicators, it's less of an effort!
i thought the Gen III V8 only makes like 225kw... actually i'm pretty damn sure of that. It was nearly 30 kw's less than the 3.2L Straight six M3 .....hahahahha, nice one holden.
what a waste of.... litres and cyclinders and stuff...
Originally posted by whatsisname
My car has all the usual bolt-on mods including a bigger turbo, but not enough for 300rwkw! I'll get there eventually though. See my sig'. There's a few GTS25t's owners here with 300+rwkw.
Very nice! 13.1 in street trim is an awesome time! I am hoping for low 13s after my first round of mods.
Correct 225kw, but they are in fact detuned in stock form they produce 250kw in the US But Holden detuned them for our market. Mind you with just an exhaust and a rewrite of the software with LS1 edit and you are looking at 230rwkw. Not bad for $3k. Also I know of a new 225kw Holden ute that ran consistant 12.2 at EC with only exhaust, LS1 edit and a small cam.
Thanks mate. Yeah I've only ever run in street trim.
It should go a bit quicker again as I've done quite a bit of work & gained a few rwkw since that run.
Hope ya' nail low 13's mate.
Guest BLKGTST
I would not be so quick to put down an LS1 powered commodore, i own one a VX berlina( MY tow car) and a R33 GTST, unfortunately currently my LS1 is quicker than my skyline, commy runs a 13.3 with only exhaust , diff gears and tune. The Gtst runs a 13.8 with higher boost exhaust pod filters and chip. Now me and my brother have raced them and the berlina is a good 5 cars quicker from a standing start, of coarse we swapped drivers to make sure and again pulled the same, so what begain as my tow car for my boat has now started to pull funds away from the skyline mod account.
the ls1 is a mean motor. I know there are plenty of fairly slow stock commodores around sporting them, for instance the GTS monaro I hosed this morning on the freeway on ramp. But it doesn't take much to free up the power lurking beneath and there are some very good street weapons just waiting to show a gtst how mortal it is (even if it doesn't look very good doing it).
boys I am an import lover as much as the next. But you guy have got to watch out for the pushrod motor... they are very angry when they are derestricted. remember the quickest "street" cars in australia and america aren't powered by fuel injected, over head cam wizardry... top fuels?? no computers and technology... just top gun performance.... but just the same... I really really love my imports.... they can drive you around australia and then run 11's and that is awsome....
